If we get a GM 427...
The 427 LS7 they're building for the C6 Z06 is being hand-assembled by one tech per engine in the new engine assembly plant they recently announced. The LS7 is the first engine to be built there. The new plant was described as a low-quantity center for hi-po engines. Capacities for the plant were characterized as relatively low so it seems highly unlikely that they will have crate engines available for general public consumption. Most likely, any excess capacity would be reserved primarily for warranty and in-house use. Plus, the low quantity and labor-intensive nature of the engine would make them expensive.
The 427 LS7 they're building for the C6 Z06 is being hand-assembled by one tech per engine in the new engine assembly plant they recently announced. The LS7 is the first engine to be built there. The new plant was described as a low-quantity center for hi-po engines. Capacities for the plant were characterized as relatively low so it seems highly unlikely that they will have crate engines available for general public consumption. Most likely, any excess capacity would be reserved primarily for warranty and in-house use. Plus, the low quantity and labor-intensive nature of the engine would make them expensive.I agree and disagree with Patches - The motors will surely cost more than a LS6 crate but I will bet they will undercut the 20K price you need to spend @ a tuner to get one now.
Is there and hard data on how many C6 Z06/7 they are going to produce. If they turn out 5k to 10k of these cars a year I would guess that we will see a crate motor from GM.
I believe I can get a C5R block for <$6.5k, a Lunati stroker kit for <$4k and stage II heads/cam for <$3K = $14k. I don't know how much the electronics cost but it is probably less than the core I'm required to send to a tuner.I saw a NASCAR contest where they had crews put together an unassembled motor. I remember five maybe six guy put the motor together in minutes
I'll give the GM tech 24 hours and gladly pay $150/hour ($3.5k).So $17.5k for a crate 427 should be the maximum. The block, stroker kit and heads are already at retail price so it should be lower. Plus I would have an LS1 that I can sell for at least the cost of the installation of a 427
I'm guessing $10-12k for a LS7. Hopefully they don't go to the price extreme LT5 crate motors sold for.
For my $, its going to be a 6.4 liter making around 505 HP and in a 3000 lb car it will still fly regardless.At any rate, if the Z06 makes at least 500HP at the crank, i believe regardless what the c.i.d is the car is going to cost around $70,000.00!!
IF the motor is a 427 7 liter and i HOPE IT IS, to order that motor by itself from GM will be VERY VERY EXPENSENSIVE and the tuner built strokers will be the cheaper way to go in my honest opinion!!!
COME ON GM GIVE US WHAT WE WANT-427 CUBES and at least 500 PONIES AND TORQUE oh yeah, and only a $60K price tag (not)!!!
Consider the C6 is still using the same basic rearend, drivetrain components, etc as the C5...and as you've recently found out on your beast, those parts ain't gonna cut it in with 500hp in the average consumer's hands.
We all want the power yes, and that's relatively easy for GM to deliver...but what about everything else that needs to be beefed and upgraded to reliably support it? And all those compnenents will cost $$ to tool up and build. They have warranty claims to worry about.
If you look at the C6's now, the General is still keeping things priced VERY well for us, as the C6 stickers for $1k less than an 04 did (this is base price).
I think that they'll try to keep it affordable and my hat is off to them, and hope that they can do it. If they do price it at $70k, then $100k for a Blue Devil won't seem so bad!
:I know, I have the LPE 427 in my '99
This engine will probably be, overall, better that attempting to get a GM LS7. I.e., no issues with tuning (probably will need 'new' software to address the GM 427), the LPE is 'plug and play for the C5, who knows about the same capability with the GM LS7, etc.
I personally think they would be idiots if they dont figure out some way to use a DTE like rear diff brace. How much could that cost them to fabricate and now they have a beefier rear end without spending a ton of money to completely redesign it.
