Jacking and Towing
Old Nov 8, 2004 | 07:47 PM
Jaegerhuhn's Avatar
Jaegerhuhn
Default Jacking and Towing
I have read the service manual and it suggests points for jacking in priority. It also requires the plugs for lifting the rails. Is it safe to let a shop lift it using a lift that supports the entire rail without the plugs?
It occurred to me this weekend that a wrecker could really mess up my car towing it. I could see insisting on the ride on top wrecker but where should he tie his winch to????? What about chains in the rear to secure it? Should it be loaded nose first or rear first?
Old Nov 8, 2004 | 07:55 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
The problem with the lift that supports the entire rail is that the rocker panel extends below the rails, that is the reason for the pucks. The place that does my tire work has a lift that would support the entire rail except they put rubber blocks on the lift so it lifts the rails and does not touch the rocker panels.
I have never had my '03 Vette towed, had my '79 towed and he ended up putting a dolly under the front wheels. Took him 30 minutes to figure out how to hookup to it. Since then I have requested a flatbed. Still don't know how they would hook the winch up. I would be interested in the answers.
Old Nov 8, 2004 | 09:09 PM
Jaegerhuhn's Avatar
Jaegerhuhn
I guess I should buy a set of pucks and make sure the shops use them. Towing still bothers me.
Old Nov 8, 2004 | 09:26 PM
EHS's Avatar
EHS
Absolutely use the pucks to jack/lift the car.
You can use a hockey puck, or even an appropriately sized two by four, just don't do it without anything.
Old Nov 8, 2004 | 10:22 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
There is no real good place to hook a winch to, front or rear. That is why I had tow hook installed on my car when I had the T1 upgrade done. I had one installed in front and one in the back.
Given a choice, I'd wrap a strap around the rear cross member and pull it up backwards. Hopefully, you'll never be in that situation.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 9, 2004 | 08:02 AM
Gordy M's Avatar
Gordy M
The easy way is to get the jacking pucks from a E36 BMW, not from a BMW dealer, for about 25.00 and put them in the slots and leave them. I autocross, drag, or DE my car 30 weekends a year and they have never fallen off. Anyone jacking or lifting has a hard rubber pad to protect the body from damage.
Old Nov 9, 2004 | 10:40 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Had to have mine towed a year or so ago and the guy wanted to wrap a strap around the crossmember and pull it up to the flat bed that way. I did not like this and made a few calls and was told that the way to tow it or pull it up the ramp to the flat bed is to use the same holes where the jacking pucks go and run the chains from under the front of the car and insert these shaped links (driver had them, seems they are normal to have) into the holes and then center pull from front.
Old Nov 9, 2004 | 11:56 AM
The Batman's Avatar
The Batman
Originally Posted by sweetcharity
...the way to tow it or pull it up the ramp to the flat bed is to use the same holes where the jacking pucks go and run the chains from under the front of the car and insert these shaped links (driver had them, seems they are normal to have) into the holes and then center pull from front.
I had my 2002 flat-bedded a coupla weeks ago (un-pluggable cut in left rear), and this is exactly how it was done.
Other jacking observations: My Harbor Freight low-profile "racing" jack wouldn't fit under the car with the flat. I jacked the car from the rear crossmember instead.
If I had gotten a flat on the front, I would've had to use a combination of jackstands and jacks to raise the front, that is, if I didn't have a spare F-body scissors jack. The F-body scissors jack collapses to about 1 & 1/2 inches, and it'll easily fit under my lowered C5 with a flat. Not as light and elegant as the MB little jack that Frederick offers, but the notched saddle does sit more securely against the A&A rocker rails that I have, and since it has a large base and is beefier, I feel a little better with it under my car.
Old Nov 9, 2004 | 01:01 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
The links you mentioned are called T-Hooks. I found out about these on the forum a while back when inquiring about best way to tie down car to trailer. I bought 4 of them for securing car to trailer & works great.
Hadn't thought about using them for winching but sounds like a great way to safely pull it on a flatbed hauler. I'll try this if I ever have to winch it on one in the future.
Here's a link to where I bought mine. It's probably a good idea to have a set of these around for an emergency.
http://www.awdirect.com/awdirect/cat...ion&linkid=110
Old Nov 9, 2004 | 01:31 PM
sweetcharity
Thats them exactly. I was so happy he had some with cause the alternative (his way) was unacceptable to me.
Old Nov 9, 2004 | 05:42 PM
Jaegerhuhn's Avatar
Jaegerhuhn
Thanks guys! I ordered the hooks. I don't want to depend on a wrecker to have them even though they probably do. For $20 incl shipping it is cheap insurance.
As for the pucks? Where do I get them for $25?
Old Nov 9, 2004 | 06:31 PM
John Nowak PE's Avatar
John Nowak PE
We had to have ours towed once..... A car of teenagers signaled they were turning right and pulling off the road, then they suddenly turned left in front of us
Ours was towed by using a "tire lift" tow truck (don't know the correct technical term for it). It has two parts to the lift assembly; the truck backs the front part until it touches the front of the tire - then a second part is connected to the rear of the tire (like how a car dolly normally works). Hydraulics lift the whole assembly, lifting the care by the wheels/tires. A sling-type strap hold the wheels to the lifting assembly and a way you go.
Didn't have any problems hooking it up (only took about 10 minutes), or towing it in to town.
Old Nov 9, 2004 | 06:34 PM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Hey subdriver, where/how was the tow hook installed??
i just started going to the Speedventure events and they "strongly" recommended having tow hooks.
i'd sure appreciate any info.
Old Nov 9, 2004 | 06:43 PM
Z06-JIM's Avatar
Z06-JIM
I would also be interested in seeing pics of the tow hooks that subdriver is refering to!
It sounds like they might be permantly installed?
If so, what did you attach these to and how are they installed?
Old Nov 9, 2004 | 07:04 PM
Jaegerhuhn's Avatar
Jaegerhuhn
There is a picture of the tow hooks above under Z06 Jim. I ordered them just in case. I was glad to hear it can be towed with a standard hydralic wrecker. I was told it would mess up the front end.
Old Nov 9, 2004 | 11:28 PM
C66 Racing's Avatar
C66 Racing
I use those t-hooks pictured above to anchor my car to my trailer. I didn't realize tow truck drivers carry them. Nice to know.
The tow hooks they are referring to on my car were permanently installed by Phoenix as part of my T1 install. The front one is bolted to the bottom of the bumper and comes out the driver's side screen mesh in the nose. The rear one is bolted to the bottom of the rear bumper and comes out the muffler slot on the drivers side. My tow hooks took a beating at the Runoffs as I had to get towed in twice, once for the harmonic balancer bolt coming out, then again shortly thereafter when the motor gave way totally. I noticed that the tow hooks had a couple of the bolts that hold it to the bumper break. I also know Phoenix has started welding them to the bumper. I will either replace my bolts with grade eight this winter, or learn to weld.
Here is a picture that sort of shows where it comes out. You can see a little white decal with a red arrow pointing down to the tow hook coming out the driver's side screen:
Old Nov 10, 2004 | 12:21 AM
Z06-JIM's Avatar
Z06-JIM
Thanks subdriver, I think I understand now.
The tow hooks you had installed are mainly only for race cars that might need towing to the pits/trailer on a more frequent basis or to remove car quickly off the track for safety reasons.
I doubt if they would be very desirable for street cars, right?
To Jacking and Towing
Old Nov 10, 2004 | 04:11 PM
C66 Racing's Avatar
C66 Racing
Exactly. They are really for getting pulled out of a gravel trap, or getting towed off the track and back to the pits for mechanical failures. As they stick out several inches, they are real knee knockers. Not something you would want on a daily driver. Now if you track your car regularly, you might want to think about this.
Old Nov 10, 2004 | 04:37 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Buy a set of pucks and carry them in the storage compartment so you'll always have them with you.
Old Nov 10, 2004 | 08:45 PM
EHS's Avatar
EHS
That's what I do, and they still don't use them.
