Two easy questions:
Old Nov 8, 2004 | 07:53 PM
servohead's Avatar
servohead
Default Two easy questions:
1) When should my cooling fan come on? Driving the coolant temp is 185 ish (farenheit) but idling in traffic it slowly rises to around 230. ?? Is that ok?
2) Idle shakes. It's not misfiring but its not a completely smooth idle. I just installed new spark plugs and wires (small change in idle quality). Is there a normal amount of uneven-ness with the LS1 at idle? To add - My car is bone stock.
I know I've been asking many questions, but being new to this car I'm eager to learn and fix what needs to be fixed so I can relax. Thanks guys.
Old Nov 8, 2004 | 08:07 PM
chaase's Avatar
chaase
St. Jude Donor '12
1) I am pretty sure that is normal. Mine does the same thing if the weather is hot and I am in traffic.
2) The idle should be baby smooth. I get a twitch in RPM on occasion, but no shaking. I would check the plug gaps to make sure that they are correct. (I don't know what is normal for the LS1)
Old Nov 8, 2004 | 08:37 PM
servohead's Avatar
servohead
For the spark plugs I chose the AC iridiums which are pre gapped, and you can't adjust them anyway. To be more specific the idle is way smoother in the morning when I start it up. It starts to run uneven at operating temp... maybe I should run a vacuum test to see what it is at idle. Car performs nicely other than that. Thanks for the reply!
Old Nov 8, 2004 | 09:06 PM
jmiller's Avatar
jmiller
I have the same issue on mine as your #2 question. I am going to try new plugs and wires. Curious as what others say...
Old Nov 8, 2004 | 09:34 PM
shurite44's Avatar
shurite44
Default run cooler
I put in two cans of 40 below in my coolant system. I guesstimate it runs 15 degrees cooler average.
Old Nov 8, 2004 | 09:35 PM
servohead's Avatar
servohead
Miller,
So we might compare idle quality when the motor is hot; the amount of roughness I'm feeling is noticable to cause concern but not so rough that the motor feels as it might stall. My shifter will jiggle a little and you can feel motor-shake in the seats. I've seen alot of chevy V-8's do this before. It's just weird, I'd think you could get a "baby smooth" idle out of it as chase said. My car has 40 k on it so you know.
Old Nov 8, 2004 | 09:55 PM
jfrc's Avatar
jfrc
2) this is with stock cam/heads?
Old Nov 8, 2004 | 09:57 PM
servohead's Avatar
servohead
Yup. Stock everything.
Old Nov 8, 2004 | 10:08 PM
Dope's Avatar
Dope
Resident moron
I've watched stock LS1s idle from the engine bay and they do shake a good bit. Stock 2000 SS, stock 2002 Z28, stock 99 C5, stock 03 Z06, etc.
It's impossible to know how much vibration you're talking about, but from what you're describing it's normal. These engines most certainly do not idle 100% perfectly.
Dope
Old Nov 8, 2004 | 10:15 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Hey Steve Martin, I bet you get kidded with that monikker. Is it a shake or a lope? Corvette's stock cam isn't going to give you Lexus smoothness. If it's more than typical rocking, sounds like a compression/ leak down test is in order, also a valve spring check.
Old Nov 8, 2004 | 10:18 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Temps are normal. The thermostat begins to open at about 185-195, so that should set your lower temp. The fans come on in high speed at about 230 or so which is why you see that temp in hot low airflow conditions.
Many don't seem to like that temp, and use programs like LS1 edit to reprogram the fans to come on at a lower temp, like 210-220.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 8, 2004 | 10:27 PM
servohead's Avatar
servohead
Yeah I do get jokes all the time about my name. Oh well, named after my uncle. I'm still a wild and crazy guy though.
Ok so I am used to working on volvo's, which all have very smooth running engines nowadays. It is possible that my motor is idling normally. With no codes stored over the 1000 miles I've driven it I'm pretty sure everything is ok. You guys are really helpful by the way. I really appreciate it!
Old Nov 8, 2004 | 10:46 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
My car is also bone stock (internally), and it shakes and shimmies with the best of them, and did so on the original plugs (had 13K on them when I tossed them) and on the brand-new Bosch's. Yes, I agree that you would think these motors would idle very smoothly, but they do not, and yes, it's normal.
Old Nov 9, 2004 | 11:00 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You are not going to get a completly smooth idle with an LS1. It's a V8 with an agressive stock cam. It also has a poor H pipe design so balanced scavenging from the left and right exhaust manifolds will cause alittle roughness.
As far as the fans go.. here is the prgramed sequences:
Depending on the model year...
For later model years:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years:
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
I hope you enjoy that car.
welcome to the forum seeya
Old Nov 9, 2004 | 11:46 AM
JasonFRC's Avatar
JasonFRC
Steve,
As the previous post stated a bit of shake seems to be the norm. As fart as temps go, I'm going to get a cooler thermostat and re-program my fans using LS1 edit.
Doesn't that Volvo inline six run smooth? I spend all my time working on Volvos as well. We have a bit in common, I own a Volvo shop, and I also have a '99 Pewter Hardtop.
Old Nov 9, 2004 | 07:33 PM
servohead's Avatar
servohead
Wow! a volvo shop eh? I've been working for a volvo dealer as a technician for the last 2 years and i love it. Volvos are great to work on for the most part. You can understand how I'm a little picky about my idle quality as I am used to the 5 and 6 cylinder motors. Aside from this new vette I have a '96 850 turbo all modified up to about 300 hp which is fun to whip around(which is kind of all you can get safely out of it).
As far as that lower temp thermostat your going to put in: I thought about that, but what stops me is I don't know how the computer is going to take to it. Lower ECT temps I would worry would change the running parameters too much. However, I would love to see my LS1 run a little cooler.
Old Nov 9, 2004 | 08:35 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Man, this forum is the greatest. I was wondering about the idle on my C5 when I bought it last week...now I can quit worrying about that..
To Two easy questions:
Old Nov 9, 2004 | 08:36 PM
Donovan 572's Avatar
Donovan 572
Originally Posted by JasonFRC
As fart as temps go...
A little typo there?
(sorry, couldn't resist)
Old Nov 9, 2004 | 08:40 PM
Donovan 572
Old Nov 9, 2004 | 08:56 PM
jfrc's Avatar
jfrc
but no easy answers
