LS2 TBody on LS1????
Old Nov 9, 2004 | 07:29 PM
TANGLVR's Avatar
TANGLVR
Default LS2 TBody on LS1????
Does anyone know for certain if the LS2 90mm Tbody will interchange with the LS1 Intake manifold? A couple people told me they think so but I don't want to buy one if I'm not certain.
THX!
MM
Old Nov 9, 2004 | 07:49 PM
RoadRebel's Avatar
RoadRebel
Um...
No the Ls2 TB will not fit on a LS1 intake
Yes, you can use the LS2 intake and 90mm TB on an LS1/LS6
Use the search button and all the info is posted by myself
Phil
Old Nov 9, 2004 | 09:02 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Have you actually run the LS2 TB on a C5? I know the intake bolts to the heads. The latest GM Hi-Tech states the C6 LS2 TB does not contain an electronic throttle control that was in the C5 TB.
BTW half the time the search function does not work on CF.
Old Nov 9, 2004 | 10:06 PM
ZO6PARTS's Avatar
0ZO6PARTS
Supporting Vendor
Default Been there done that!
Check it out!!!!!!
http://www.z06vette.com/forums/showthread.php?t=70047
Old Nov 9, 2004 | 10:28 PM
RoadRebel's Avatar
RoadRebel
Yes I do run one..one of the first actually..All the info is posted as well as some pics. If he needs it I can repost or send to him
BTW..its worth a decent chunk of power on anything making more than oh 475ish to the ground. Livernois recently got 20hp and more rpm out of it over and ls6 on a 383 stroker they ran at Thunder
LS2 install on LS1
Phil
To LS2 TBody on LS1????
