fuel filter question
Old Nov 9, 2004 | 11:44 PM
rcknusa's Avatar
rcknusa
Default fuel filter question
I have a 2000 coupe and it is about time to change the fuel filter. I have owned the car since January 2004 and think I ought to replace the fuel filter.
1. Where is it located? I believe I found it on the driver's side rear but it looks like I may have to unbolt the exhaust right there to actually get my hands in there and get the filter out.
2. Can I got to Autozone ect. or do I have to purchase from dealer?
Thank you for your help.
Old Nov 10, 2004 | 05:01 PM
2KVetteMan's Avatar
2KVetteMan
Just did my fuel filter myself a while ago, Here is what I went off of, my vette is M6 so its just a little different step for you. Of course this credit goes to a fellow member info "FRPTech"
Replacing the fuel filter is a little messy, but, not terribly difficult...
You will need a fuel line disconnect tool and handy socket set...
- Relieve the pressure in the fuel line at the rail.
- Disconnect the battery
- Raise the drivers side rear of the car
- Since you have an A4 as I do, space it tight and it helps if you remove the catback portion of the exhaust on the drivers side.
- The filter is just up under the frame in front of the drivers side rear wheel
- Remove the bolt holding the filter assembly to the frame
- This is where it gets messy... Remove the two quick connect fittings towards the rear of the filter, just squeeze the blueish colored tabs and pull the two lines from the rear side of the filter. DO NOT be right under this - a couple of cups of gas will come pouring out - trust me I got soaked...
- Using the fuel-line disconnect tool, remove the line on the front side of the filter. This is tight, I was worried about snapping the line when I did mine but it will come out... Again, some gas will pour out and remember the filter itself is full.
You MUST use the fuel-line disconnect tool here. Its a little plastic ring with a cutout and tail that slide between the connector on the line and the hard tab on the filter. Same tool is used if you ever remove the line from the fuel rail...
- Clean up all of the fuel that went everywhere
- Put the new filter in place and bolt it down.
- Reconnect the lines.
- Reconnect the battery
- Turn the key in the ignition to pressurize the lines but do not start
Do this two or three times
- Check for leaks
- Replace the catback if you remove.
- Lower the rear of the car.
- Take it for a spin
Its not too bad, takes me about an hour and I take my time...
FRPTech
Old Nov 10, 2004 | 05:03 PM
2KVetteMan's Avatar
2KVetteMan
Oh I had to buy the filer at Chevy dealer. My local Pep Boys, Napa and Auto zone did not carry the filer
Old Nov 10, 2004 | 05:30 PM
Jim D's Avatar
Jim D
Where do you get the fuel line disconnect tool at, thanks Jim.
Old Nov 10, 2004 | 05:39 PM
2KVetteMan's Avatar
2KVetteMan
I didn't buy one. ONLY!!!! because my vette was sitting for 2 weeks in the garage and the fuel pressure. Well there was none since it has not been running.
I just used a long needle nose pliers.
Although would I do that again. NO!!! I almost broke the ring off. I asked all the places I went to and they looked clueless. Someone suggested just using a screw driver to relieve the fuel pressure.
I didn't ask NAPA, they might have it.
Old Nov 10, 2004 | 05:43 PM
rcknusa's Avatar
rcknusa
Thank you very much that is fantastic help.
2KVetteMan's Avatar
2KVetteMan
Should of gone to NAPA Good luck.
NAPA TOOL
In the search field type "Fuel Disconnect" you will get the hit.
Old Nov 10, 2004 | 09:45 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL sells a high quality fuel filter made by Hastings for the C5/Z06. I have replaced mine per the above and it is pretty easy... once you have the fuel line tool.
AMSOIL sells the following filters/parts for your car (all available via the link to the left):
2000 CHEVROLET CORVETTE 5.7L 8-cyl VIN Code G
FILTERS
Oil Filter......SDF32
Air Filter......TS83
Fuel Filter......GF336
PCV Valve......HV199
BOSCH SPARK PLUGS
Wire......B09448
Plug......B4458
BOSCH WIPER BLADES
Driver side......B40922
Passenger side......B40922
Buy AMSOIL at Wholesale
AMSOIL Preferred Customer Program allows you to buy any AMSOIL product at wholesale, which is about 20% less expensive than retail. Cost is $10 per six months and you can buy as much oil as you want during that six months. To sign up, all it takes is one phone call to 1-800-777-7094. Give them reference number 1206638.
Or you can use this link:
Again, please put 1206638 in the customer number block.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To fuel filter question
