Interior lights Out
Old Nov 10, 2004 | 03:49 AM
Stellar112's Avatar
Stellar112
Default Interior lights Out
Unfortunately my interior lights, meaning the lights that light up the floor no longer come on. The light in the back of my coupe on the driver's side is also not coming on so I'm hoping their all related to one fuse? I'm hoping this is as simple as changing a fuse, and if so which one is it? I can't find my manual for the life of me and its been very frustrating. Of course I have been stuck working long hours so I haven't been able to really look into it. Any info/suggestions will be greatly appreciated.
Old Nov 10, 2004 | 06:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are a lot more lights that may be out and could give better clues as to the location of your problem. Try this: Look at the Instrument panel fuse box (passengers foot well) and check the (Monitored LD fuse, micro fuse #2, if that is good the, the Monitored LD relay could be bad. Relay#37
Check the following lights: Right and left mirror vanity lights, Rear view mirror lights and the under hood lamp along with the interior lights and see if they work.
I recommend checking the fuse and power to the fuse and relay with a meter.
Please let me know what you find.
Bill C
Old Nov 10, 2004 | 10:35 PM
G-lock's Avatar
G-lock
Default Check fuse 29
I had this problem after I did my electro mirror install. It's labelled diagnostic in the fuse box in my 99. Jeff
To Interior lights Out
