Clutch --> Centerforce, RAM, or SPEC?
Old Nov 10, 2004 | 12:06 PM
Jman's Avatar
Jman
Default Clutch --> Centerforce, RAM, or SPEC?
I have found 3 different clutches that look like they fit my application:
My price range is between these 3 clutch kits:
RAM Powergrip Clutch Stage 1
Centerforce Dual Friction
SPEC Stage I
Which one do you think would be the best bet for a stock to mildly modded LS1 Fbody?
Old Nov 10, 2004 | 02:23 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
For a stock to mildly modded F-body I would go with a Z06 clutch. Many have posted problems with the above listed clutches and there is no need to go aftermarket with only mild mods. The Z06 is cheaper and comes with a flywheel and is zero balanced.
Check out carolinaclutch.com.
Old Nov 10, 2004 | 02:39 PM
kumar75150's Avatar
kumar75150
ya if you are under 400rwhp and dont drag race the car much, I'd go with a Z06 clutch and hydraulics
Old Nov 10, 2004 | 05:06 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Old Nov 10, 2004 | 07:11 PM
T_Vert's Avatar
T_Vert
i have the z06 clutch and it lasted about 5k miles before the pedal started to stick to the floor w/ my long tubes, 4.10s and vararam. I had a new z06 slave and master put in and the drill mod done too. I also insulate the line by my long tubes.
Dave
Old Nov 10, 2004 | 09:54 PM
db2xpert's Avatar
db2xpert
I just had a SPEC pressure plate housing crack..... one of the bolt mounting areas was almost off the whole assembly.
The pressure plate face itself was fine.
This had been in there for about 2 years.
There was often some sporadic chatter when comiung off a dead stop.
Now have a twin disc Exedy. Pricey, but really nice.
No chatter, smooth engagement. Very short throw clutch.
Joel
Old Nov 10, 2004 | 11:57 PM
Tsab's Avatar
Tsab
I have the Z06 Clutch and flywheel and have about 25+ launches on it.
No problems to speak of. I'm also running about 525 crank hp. Z06 clutch should be more than adequate for your application in MHO.
Old Nov 11, 2004 | 01:17 AM
88sk's Avatar
88sk
LUK gold is used by alot of tuners.
To Clutch --> Centerforce, RAM, or SPEC?
