Changing website
Old Nov 12, 2004 | 06:43 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Default Changing website
Hey guys,
I need some feedback on our web site. We have not changed anything for some time, but the future is now. I'm not a computer person at all, as some already know, so I need good and bad. Please try to be nice, because I'm still learning!
Randy
www.dougrippie.com
Old Nov 12, 2004 | 07:14 PM
Dave68's Avatar
Dave68
Default Nice!
Randy,
Great job! I especially like the green text on black background - very easy to read. Although I didn't have enough time to peruse the entire website, I did notice a couple of areas that could be improved:
1) In the induction section, the Blackwing description column should be left-justified and a bit wider; there's plenty of space.
2) There is no description of the Halltech Stinger.
3) There are no "Buy now" buttons. Impulse shoppers use credit cards. It looks like they must call to order.
4) The Blackwing is also listed in the "Exhaust" section
Other than these minor details, the site looks very proffesional. I hope to improve mine to your site's level someday. Hey, practice makes perfect!
Old Nov 12, 2004 | 10:58 PM
Paras's Avatar
Paras
Randy,
I used to check out your old site and just now saw that you have a better layout... I like it! Oh, your link to the E-bay store is not working. Good luck with it!
-Paras
Old Nov 13, 2004 | 02:22 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Nice job Randy. I didn't look at the entire site, but I did notice one thing on the main page that is a problem. You have a horizontal scrollbar on the main frame, even though there is no content on the right side after the user scrolls over.
You can fix it by eliminating the following chunk of code in main_page.htm:
Code:
<!--[if gte vml 1]><v:shape id="_x0000_s1026"
 href="drm/onelap_2003.htm" style='position:absolute;margin-left:761.25pt;
 margin-top:444pt;width:78pt;height:1in;z-index:1;
 mso-position-horizontal-relative:char;mso-position-vertical:absolute;
 mso-position-vertical-relative:line' coordsize="1560,1440" o:button="t"
 path="m90,45l435,150,825,15r330,120l1485,r75,615l1305,1140,840,1440,300,1200,,735,90,45xe"
 filled="f" stroked="f">
 <v:fill o:detectmouseclick="t"/>
 <v:path arrowok="t"/>
</v:shape><![endif]--><![if !vml]><span style='mso-ignore:vglayout;position:
absolute;z-index:1;left:1015px;top:592px;width:104px;height:96px'><map
name=MicrosoftOfficeMap0><area shape=Polygon
coords="6, 3, 29, 10, 55, 1, 77, 9, 99, 0, 104, 41, 87, 76, 56, 96, 20, 80, 0, 49, 6, 3"
href="drm/onelap_2003.htm"></map><img border=0 width=104 height=96
src="main_page_files/image001.gif" usemap="#MicrosoftOfficeMap0" v:shapes="_x0000_s1026"></span><![endif]>
What that code does is define an image map that is outside the page border. Since there is no target defined for the image map, it is completely useless and serves no purpose.
Delete that chunk of code, and find some way of appealing to impulse buyers (as suggested by Dave), and you will have a winner.
To Changing website
