Mods History
The TEA 2.5's did the trick.
...........................HP..TQ..GEAR. ..TC....cam
all stock.............. 283 310 3.15
mods listed *........368 351 3.42 sy3500 222/222
mods listed **..... 362 366 3.90 pt4000 228/228
mods listed...........382 380 3.90 pt4000 228/228 + 90 mm Fast/NW TB
mods listed...........407 374 3.90 pt4000 228/288 + TEA stg 2.5 2.055/1.57 comp. port and polish, 11:1CR
Best 1/8 mi *....................................... 7.50 94.79 1.61 3.42 SY3500
New Cam, gears and TC**........ 3/8/04....7.29 94.11 1.59 3.90 PT4000
90mm TB, intake.......................5/3/04..7.199 95.79 1.571 3.90 PT4000
TEA stg 2.5 heads times to come
Mods: Eastcoast deep pan, B&M trans cooler, Transgo(full kit), alum.acc.piston, 9 disc C.Pack,
Z06 exhaust, Vararam, Z06 style screens, silicone coupler, LS1 edit, EFI live,
Techedge WB, TEA Z06 heads (2.02/1.55 valves,Comp 987's), ,
HS rebuilt rockers, CC hardened pushrods, FLP headers, Rollmaster 2X roller chain, ASP UD pulley, Magnecor wires,
NGK iridium plugs, 30# inj., PCV mod, 180* thermo shim, Hurst line lock, 17" MT ET streets. 3.90 rear w/hos, PT4000, 90mm Fast intake, N Williams 90mm TB,93 Pony 228/228 588/571 112 0 adv.
10-8-04 TEA stg ll 2.055/1.57 competition port and polish, 11:1CR
Joe's car started as a stock LS1- now, with bolt ons, he's above 400 RWHP with a moderate cam (228!). This proves that the right combos DO maximize efficiency - HP. This is an A4 car that runs/drives as stock!! No surging, no cruise-control, no hiccups - nothing....like stock but with over 450 crank HP.
I'm friggen AMAZED!!
Congratulations Joe!!! You did it!
Thanks and the check is in the mail.
I'm surprised too. There have been a number of posts asking to share the results of mods progressively. So, here's one.
DBN,
I will if I can find a track open around here. That's what I'm really interested in, though I will admit 400 is an exciting result for me.
Good luck with your improved Vette.
