underhood light problems
Old Nov 14, 2004 | 09:04 PM
wantmyc5's Avatar
wantmyc5
Default underhood light problems
Hey all -
Just got myself my first Vette - 98 C5, and I'm having problems with the underhood light. Thought it was just the bulb burned out. Tried to replace it, and as I was putting in the bulb, it lit briefly, but never came on again, even after I fully installed it. Should I be checking for a switch somewhere, or is there something else I'm missing?
Old Nov 14, 2004 | 10:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a connector on the fan shroud (passengers side) that is often unpluged and could be loose. Give it a check and see if it is loose.
Bill C
Old Nov 15, 2004 | 01:34 PM
djengr's Avatar
djengr
Default Hoodlights
Check to see if you blew a fuse, if your vanity lights are not working and they used to work you may have blown a fuse. Also the reading lights on the inside rearview mirror come off the same circuit. The fuse is located under the passenger foot panel, I think it called inadvertent load.
Old Nov 15, 2004 | 01:50 PM
C5 ChemE's Avatar
C5 ChemE
Bill C
When I picked mine up, the light was out and couldn't figure out why. After the dealer put a new bulb in and still didn't work, we saw the connector was unplugged :o
To underhood light problems
