Control arm bushings
Old Nov 14, 2004 | 03:40 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Default Control arm bushings
Want to get a poly set,but which one???? Just need the control arms.The springs are coming off in favor of coilovers and I have T1 bars ,so the sway bar bushings in most the kits I found will not work with them. What would you recomend?? TIA
Old Nov 14, 2004 | 05:01 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Vette Brake Prouducts their T-1 bushing are harder too. You may want to get the whole kit. You can also grese them with a neddle fitting later.
