rear gears
Old Nov 14, 2004 | 08:10 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default rear gears
I am thinking about changing my rear gear ratio. However how would the gears affect me at the quarter mile track? I am running an MN 12, what would my top mph be in 4th gear?
3.42's
3.73
3.90
4.10?
Thanks in advanced!
I am also planning on using the DTE brace, any other must have parts?
Chris
<edit> assuming stock size tires
Old Nov 14, 2004 | 08:33 PM
gojo's Avatar
gojo
With 4.10's if you hit 121mph it would be 6500 rpm's.
[IMG]http://www.smokemup.com/auto_math/mph_range.php[/IMG]
You can calculate here.
Old Nov 14, 2004 | 08:48 PM
Stangkiller
That site requires a password, any other sites? Sounds to me like 4.10's wouldn't be a very wise move with 3.42's trapping 117 and i'm hoping to ad more power very shortly
Old Nov 15, 2004 | 10:49 AM
Stangkiller
Ok, so i found a site and have the results. I calculated my new tire is going to be 315-30-18's is going to be a lower tire than my current diameter. Currently with stock 3.42's and stock size tires i'm trapping between 116 and 117mph, If i were to upgrade gears i would be raising my mph by a few correct? And calculating that and the possiblity of spraying the car or adding heads or a bigger bottom end, i should plan for at least 125mph in 4th gear....therefore the 4.10's would be too big of a gear and i'll need to stick with the 3.73's? That being said, will the 3.42 to 3.72 change be a big enough jump?
Old Nov 15, 2004 | 12:26 PM
gojo's Avatar
gojo
With 3.90's you would do 126mph in 4th at 6500rpm's. That would be perfect for me, since I don't mind reving over that. But that's me.
To rear gears
