335's on 11 inch rim?????
Old Nov 15, 2004 | 03:39 PM
3XBlack6spd's Avatar
3XBlack6spd
Default 335's on 11 inch rim?????
Does a 335 Series tire on a 20x11 rim fit under a stock Z06?????? I usaully see guys with 335's have mini tubs, but is that because the 335 tire, or the 12 inch rim??????????????
Old Nov 15, 2004 | 03:59 PM
ICULUKN-C5's Avatar
ICULUKN-C5
depends on the backspacing. I have a 335 on a 11.5" rim. It does stick out about 1/2". To me its a small price to pay for all that bologna under the rear.
Old Nov 15, 2004 | 04:13 PM
3XBlack6spd
so in that case...my rim would only be 11" so it should fit?
Old Nov 15, 2004 | 05:02 PM
Dope's Avatar
Dope
Resident moron
With the correct backspacing and such, it should. You didn't list backspacing or offset or anything.
Dope
Old Nov 15, 2004 | 05:30 PM
philthy's Avatar
philthy
From: Land of the heartless the home of the paid. Miami FL
I have 18/11/335 and never a single problem no rubbing no, no nothing! Plus I drive the car at least 175miles a week.
Old Nov 15, 2004 | 05:37 PM
tjkzo6's Avatar
tjkzo6
I have a set of CCW's (18x11.5) with Mich PS 335's on the rears and they stick out 3/4" outside the fender wells.
But they look double bad! I don't think there is a need to mini tub at least I didn't have to, however with different wheels you may have wierd offsets and hence have to do something different.
Good luck, TJ
Old Nov 15, 2004 | 05:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you're thinking of the Michelin PS2 335/30/20, do realize that tire is 28" tall, or about 2" taller than stock Z06 tires.
It's also recommended for a mnimum of 11.5" wheel, but I suspect you could squeeze it on an 11.
To 335's on 11 inch rim?????
