Clutch fluid change.... How?
Old Nov 15, 2004 | 06:54 PM
servohead's Avatar
servohead
Default Clutch fluid change.... How?
Hey guys,
I flushed the brake fluid in my car the other day and noticed that the clutch fluid is also pretty dirty. How can I flush it? Looking at where the lines go it doesn't look very possible.... Thanks!
Old Nov 15, 2004 | 06:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you do A LOT of disassembly and open the bleeder on the slave cyl, all you will be able to do is suck all of the fluid out of the master Cyl with a syringe, turkey baster, or bulb syringe, wipe it out and refill it. It doesnt sound like much but some of the fluid in the line will exchange and you will end up doing it again in 2-3 months.
BC
Old Nov 15, 2004 | 07:11 PM
servohead's Avatar
servohead
aah I see. Will do then. And I'll use that special GM clutch fluid that you guys were talking about instead of regular Dot 3 for good luck.
Old Nov 15, 2004 | 08:39 PM
Patches's Avatar
Patches
LAPD sells a bleeder extension that I have now but can't install until I do a clutch change or just pull the drive line. One of my few gripes with C5 engineering- wouldn't have killed them to put an accessible bleeder line in.
Here's a link to the procedure. I hope you're sitting down . . .
http://97vette.com/howto/clutchbleed/index.html
Old Nov 15, 2004 | 08:49 PM
Monster231's Avatar
Monster231
Holy shAT!!!! all that to bleed the line
Old Nov 15, 2004 | 10:42 PM
servohead's Avatar
servohead
Cool. That doesn't look so bad. I was worried I'd actually have to remove the torque tube to bleed it. I'm just happy I can without removing the driveline!
Old Nov 16, 2004 | 11:15 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
You can keep your fluid clean by the turkey baster method, but that won't bleed air out of the lines. The LAPD extension is invaluable and I highly recommend it if you have your clutch replaced or engine out (meaning you can get to the bleed line to install the extension).
Bleeding the clutch without this is a major PITA. Takes hours.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 17, 2004 | 07:09 AM
Patches's Avatar
Patches
I got a few pics of my buddy's LAPD bleeder line when we pulled his drivetrain.
Upstream drive shaft spline with slave. Bleeder is the line on the left.
Bleeder line is the longer one.
To Clutch fluid change.... How?
