Bad Lifter
He told me that in order to fix the lifter and replace the seven others in the head it would cost $1,950 or so. I figured if he already had to take off one of the heads, maybe I should replace them both and put in a new cam. I was pretty shocked to hear him tell me that it would cost around $6,000 to $7,000 to replace the heads and the camshaft.
1. Does that sound like a resonable price to you?
2. Do you think that just doing a cam and new heads would noticably improve the vehicle's performance?
-Thanks
-Thanks
If all that has to be done is replace lifters, which does mean pulling the heads, 1950 is still too much. If he is leaving room to pull and replace the camshaft in that total, it's not that far fetched.
If you re-use the old heads, then they will more than likely get sent out to be cleaned and decked for flat so thats some $$$ there. You could go with a set of assembled stock LS6 heads for $1500, or better yet, a set of the new AFR 205 heads for $2200.
The best thing to do if it is at all possible is do this your self. Check out the link in my sig below to see my h/c swap "tear down" and "button-up" pages to see what you are getting into. And definately check out the C5 h/c swap instructions, aka the bible, at:
http://www.ls1howto.com/
You will also see a picture of a bad lifter on my site, and yes mine did damage the cam minimally. Turned sideways in the cheesy plastic lifter guides and got beat up by the cam. I still couldn't believe it when I pulled the heads and there was plastic in there!
If you cant do this yourself, give Tony a call, or if you can swing take it up to NJ or NY to one of the better known tuners.
Good Luck!
Drop me an email if I can be of more help, just across the river here...
RUN! Way too much!
