Need help with clutch, now possibly tranny?
I've been experiencing the dreaded "sticky clutch" since Friday, and I'm trying now to flush/bleed the hydraulic system to see if I can fix the problem, at least temporarily. However, upon lifting my 2000 Vette (71,800 miles) this evening, I discovered more potential trouble: it looks like not only my clutch hydraulic system is leaking, but I've also got some fluid leaking from or around the transmission. Could this sticky clutch problem also be affecting my transmission? Other way around? Also, if my clutch hydraulics are leaking this much, is flushing/bleeding the system going to be in vain? Has my slave cylinder completely given up the ghost? Please have a look at the pictures below and share any thoughts/experience you may have. If they don't load, the links are:
http://fredonet.dyndns.org/fred/imag...lutch_leak.jpg
http://fredonet.dyndns.org/fred/imag...trans_leak.jpg
Thanks for any help!
Fred
It looks like the fluid on the tranny is coming from the connection of the tranny/rear carrier. There is no tranny fluid at that connection, but there is gear oil from the rear carrier. This is of course, assuming you don't have a crack in your tranny, or the fill/drain plugs aren't loose. Did you check for any of that?
Assuming it is actually leaking at that junction, the seal between the rear and the tranny is probably missing or busted.
As far as the bellhousing goes, I'm assuming that's hydraulic fluid and not oil. Again, did you check? If it's hydraulic fluid, it's probably the slave cylinder.
You're pretty much gonna have to remove the entire drivetrain and see what's going on. Once you get the torque tube off you can see what's leaking in there (the line or the slave), and replace the necessary components. While you're there, pull the rear off the tranny and see what's going on with that.
Seems very weird that you have 2 large leaks like that. Looks like pretty nasty leaks too.
Dope
Mark
Phoenix Performance
Speaking of that, what is this "VME" (#P100206) that I've seen? Neither GM nor the dealerships I've talked to seem to know what it is. I've got the text of it, but what type of document is this? And how can I point it out "officially" to GM Customer Assistance or the dealership?
That's because I don't believe the clutch hydraulic fluid has ever been changed until now. I've had the car for about 14 months & 12,000 miles, and I've never done it. It's a 2000 w/ 71,800 miles total. When I first started having the clutch trouble and looked in the reservoir (for the first time), the level was quite low (undoubtedly from that leak) and it was very "sludgy"-- kind of flat black. I "turkey-basted" that little bit out of the reservoir and refilled with fresh DOT3 fluid. So, don't let the color fool you-- by the location, it sure seems like clutch fluid to me.
Thanks again for the help and continued support!
Fred
I would say it's clutch fluid leaking up front. You can get a better idea of where exactly the leak is coming from if you drop the h-pipe and inspection cover but everything under there is all part of the new slave. So it's not a matter of whether it's the line or the slave, when you get a new slave it has the line connected to it all the way until the quick disconnect. Really, dropping the inspection cover would just give you a verification that it's the slave that's leaking.
Good luck.
Guess I'll have to take it to a shop and let the raping begin... I love getting to pay the penalty for an inadequate design.
Lemme ask this again: What is that VME? What does it stand for? How can I point this out to a dealer or GM?
Thanks for all the help,
Fred
P.S. Don't know yet about the tranny. I cleaned off the casing pretty well with some degreaser, and now I'll just have to wait and see if/when/where it leaks.
Now that I've been unable to fix the sticky clutch pedal by bleeding the clutch hydraulic system, I've given in and taken it to a dealership (Ivan Leonard Chevrolet in Hoover, AL). I've asked them to provide me with a diagnosis of the problem, so that I can "bend the ear" of GM Customer Assistance in the hopes of getting some financial help or, better yet, acknowledgment of this widespread issue.
However, even if the clutch assembly is fine and it is purely a problem with the hydraulics, I've asked them to go ahead and replace the flywheel, clutch disc, and pressure plate with new, Z06 parts. At 72k miles, I might as well replace those parts, as long as I'm already paying the $700 labor for them to get to the clutch anyway...
I'll keep everybody posted. In the meantime, if anyone can shed some add'l light on what this "Service VME #PI00206" is, I'd greatly appreciate it. I'd like to be able to talk intelligibly about this document, which I've been unable to do so far...
L8r,
Fred
Fred
Good Luck
