car in shop need help before paying for repairs
St. Jude Donor '11
I have a 01 coupe that has been showing service abs,traction control and active handling.the code is c1214.I took it to Chevy they just called and said that the ABS electronic brake control module is broke.$1282 bucks to fix.Has anyone had this problem and did it cost this much?
Received 3,813 Likes
St. Jude Donor '03-'04
1214 is Solenoid Valve Relay Contact or Coil Open Circuit.
First step is to check or replace the underhood fuse.
Then test voltage rates at fuse and wiring on circuit 1242 (for damage). GM emphsizes (to me anyway) to check the wiring (for what caused the failure).
Then it indicates replaying as units the BVMP (Brake Pressure Modulator) and second the EBTCM (Elec. Brake Traction Module- relays are not servicable).
I believe GM List price is $882.95 + .7 hr labor + diagnostic charges. Probably could locate a used unit for around $200.
Dealer may decline to install it. This could be DIY job.
R and R
Remove and Replace. While on an extended fishing trip that was cut short, I'd left my C5 at a dealer for an inop window and no parking brakes. The dealer's diagnosis was wrong on both counts. I took the car home and repaired both items without buying any parts. Both were caused by improper assembly at the factory. I had an inop. active handling system and found a pin pushed out of a cannon plug. Codes are like sheep, sometimes they lie.
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is a long shot but it has helped quite a few forum members and it is "FREE"!!!
Check out my electrical system post and give it a try.
http://forums.corvetteforum.com/show...al+information
You have a FRONT mounted EBTCU and the grounds for this unit use the chassis grounds that have a KNOWN corrosion problem.
I had the same issues with my 98 and after I cleaned my ground connectors it's been fine since!
I had the same exact problem on my '02. Don't know if some of the other (grounding corrosion, connector pin, etc...) suggestions would have fixed it, but I had it replaced by the dealer since it was still under warranty.
They charged GM $940+change, so this is in line with gtzy's post.
Good luck with the repair.
St. Jude Donor '11
FYI, when the service writer told me the cost I was very surprised.Told him it was bad timing with Christmas coming.He then said let me talk to my boss about it.He called back and said I would only have to pay $200 for it instead of the original $1282.I don't know how it went down so much but I wasn't going to argue.
Thanks for all the input.
Congrats though, an early Christmas present from Chevy
CI 6,7,8,9,11 Vet
St. Jude Donor '08
$200 bucks for an EBTCU? I dont think so! I wonder what they really did to fix the problem???
It would be interesting to find out!
Bill C
Bill C
The paperwork I received back shows he replaced the the ebcm.Maybe he found a way to get it done under some sort of warranty.
Received 1,681 Likes
Originally Posted by David426
360000 mile warrantty. hell of a deal!!
St. Jude Donor '11
I looked at the paperwork a little more and it seems he did find a way to get the work done under warranty.It says $200 deductable on the paperwork.So if everything is true $200 and a gift basket I gave him for the work sounds like a great deal to me.
p.s But I did get my keys back without my remote which they said is always given back to the customer when they leave the keys.So I guess its $200 a gift basket and I buy a new remote for a new ebcm.
Best of all the wife is happy and she stays out of my vette.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is your car back to 100% now?? Please let us know.
Bill
Bill
St. Jude Donor '11
The car is running GREAT my wife pulled five car lenghts on me in my vette coming home from the dealership.But she forgot to tell me we were racing (cheater).
St. Jude Donor '11
The car is running GREAT my wife pulled five car lenghts on me in her vette coming home from the dealership.But she forgot to tell me we were racing (cheater).
