C5 - Electrical Problems - Need Help!
He has no lights in the rear - tail, stop, center - nothing.
When he puts his foot on the brake his dash lights dim
When he engages cruise and turns lights on, the cruise disengages.
When he tries to lock car with the remote, the alarm goes off - when he hits unlock, the alarm stops
The remote for the hatch works fine
All of this started yesterday - today when he started out, everything worked fine - for about 5 minutes, then same issues as above
He's an Engineer and pretty good at diagnosing - can't figure this one out - all fuses are fine. He's guessing it's a ground problem.
Any help appreciated - he's calling me back tomorrow evening.
Bake
Been there!
BCM is the silver box next to the fuse box!
[IMG]
[/IMG] BCM circuit board, Shows two connectors that he will need to disconnect.
[IMG]
[/IMG] Here is the drain that can clog up and cause water in the the air box to back up and leak in the pass foot well
[IMG]
[/IMG] Dry the BCM out under a heat lamp and make sure that you do not get it too hot and WARNING! It is Eletrostatic Sensitative and will be damaged if handled wrong.
If your friend checks that out and that is NOT the problem, let us know and I will dig into the books!
You can PM me and I will give you my phone #
[IMG]
[/IMG] BC
BC
Hey Bill........nice camera you have there.......real sharp images.
He was really concerned because after I communicated with him regarding battery leakage, he found that his new Sears Diehard had leaked considerable acid into the battery tray - fortunately, there was no damage below the tray. Guess GM Delco isn't only one with battery leakage problems. Good thing he found it.
Thanks Again,
Bake
