Mod Required for WCC Wheels?
Old Nov 21, 2004 | 12:06 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Default Mod Required for WCC Wheels?
I purchased a set of WCC Drag Wheels & Tires from a fellow forum member and have heard of having to make some sort of modification to prevent rears from rubbing.
Could someone tell me what this modification is and if it will be necessary with my set-up? Pics would be great!
Rears are 17x10" with M/T ET Streets, size 26x11.5x17, and skinnies on front.
Thanks.
Old Nov 21, 2004 | 12:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I think you'll be ok with the 17's.
Many ET/street drag packages use 16" wheels, which if I recall that small dia wheel rubs the upper ball joint cap, which needs to be ground down to make the necessary clearance. You shouldn't have that problem with 17's.
Old Nov 21, 2004 | 04:08 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Modification is only necessary with the 16" wheels. Here is the look anyway.
Old Nov 21, 2004 | 07:51 PM
Z06-JIM's Avatar
Z06-JIM
Great, I guess I'm good to go with the 17's.
I appreciate the replies & pics!
To Mod Required for WCC Wheels?
