DIC Defaults...Battery?
When I run it during the day, it remains at the new settings of Oil Temp when restarting.
I believe this must be a battery issue as the battery is coming up to 4 years use.
Does that make sense?
Is the Red Optima a good selection for a replacement... I like the red since I have a red/red Z06 with engine custom red.
Thanks,
Bob
BTW, have you tried setting the memory? If your car has it, and you have set if for driver number 1, then try setting for driver number 2. Mine seems to default to driver 2, and while I am not certain that the DIC settings are stored, mine does NOT default to the odometer.
Yes, it's the FOB settings.
Set all your guages, A/C, Radio/CD, seat position, mirror position
to where you want it to default. Press and hold the 1 or 2 on the
door switches to match the FOB number.
This will set your defaults.
...George
When the voltage drops low you loose some of your storred info. A new battery should fix this problem!
If you get a Optima make sure you purchase it from a place that will NOT give you a hastle if you need to bring it back!
I had mine for 4 months and it went south! I drive my ZO6 a lot so it was NOT from letting it sit and I DID NOT leave anything on causing it to go dead!Just got a BAD one! I got mine from AutoZone. No problem taking it back!
This morning checked and its ok now.
4 years on a battery is probably about it for the OEM model.
Thanks all!
