pcm lean code 0171 hc
Old Nov 23, 2004 | 09:15 PM
dddz06's Avatar
dddz06
Default pcm lean code 0171 hc
help can anyone tell me where is my problem
Old Nov 24, 2004 | 04:07 PM
Vector's Avatar
Vector
Might want to check for air leaks behind the MAF. Might be coupling to Trottle Body. Done any work on the car intake lately?
Old Nov 24, 2004 | 07:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Intake track air leaks cause this problem If any air is getting past the MAF and is entering the intake tract, this code can be set. Remove your entire air filter system from the throttle body forward, bench it and check every connection for tightness.
BC
Old Nov 27, 2004 | 08:56 PM
GLENN43's Avatar
GLENN43
How would this code effect the running of the car ?
Thank You
Old Nov 28, 2004 | 08:28 PM
GLENN43's Avatar
GLENN43
ttt
Old Nov 29, 2004 | 08:34 AM
Vector's Avatar
Vector
Thank You
A lean air fuel mixture will build power and run great right up to the point were you fry the pistons!
If the motor runs too lean you will burn the pistons!!
Don't ask me how I know.
Old Dec 1, 2004 | 08:24 PM
dddz06's Avatar
dddz06
thanks!
Old Dec 2, 2004 | 11:51 AM
hogpowr's Avatar
hogpowr
I've got the same codes. 0171 0174. I have a thread in Scan and tune as well trying to come to a conclusion. Mine only pops up occasionally at idle. Thats it. Once in a while and only at idle. I put on a halltech stinger. I have a predator and am soliciting advice on what to adjust to eliminate the codes.
Old Dec 2, 2004 | 05:22 PM
bcresc's Avatar
bcresc
I had the same code and was told by someone who knows a heck of a lot more about this stuff than I do, to look for leaks between the MAF and throttle body. It turned out to be that the bridge was separated from the MAF, on the underside, and out of sight. Hooked it up and was good to go. It's worth a look see.
To pcm lean code 0171 hc
