Remove key and wait 10 sec.????
Old Nov 25, 2004 | 07:23 PM
XXX Vette's Avatar
XXX Vette
Default Remove key and wait 10 sec.????
I started my 97 and it started then, it said "remove key and wait 10 seconds", then the engine died. I did what it said and it ran fine, this happened 4 times so far. What's the happs?
Old Nov 25, 2004 | 07:31 PM
SmokeyTirez's Avatar
SmokeyTirez
Always try searching before asking. In this case, search for "Column Lock Bypass"
Old Nov 25, 2004 | 09:38 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Dupe!
Old Nov 25, 2004 | 10:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The resistor that is embeded in your key connects to some electrical contacts inside your ignition switch and is part of the vehicle security system. If the resistor is dirty or it didnt make good contact inside the ignition switch the security system will ask you to reinsert the key. If you do not or do and the resistance is incorrect the security system disables the fuel system if the car is moved. Usualy about 3-5 feet.
You have a couple of options. Clean the resistor contacts on the key, use your spare key or you could have a bad ignition switch and it may need to be replaced.
Bill Curlee
Old Nov 26, 2004 | 12:12 AM
SmokeyTirez
Bill you have that saved for cut and paste don't ya?
Old Nov 26, 2004 | 12:41 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No,,,,,,,,actually, I've written it so many times that i can do it in my sleep. I dont mind explaining to people who need it. I was there once!
BC
To Remove key and wait 10 sec.????
