Washer Fluid DIC
Old Nov 26, 2004 | 03:24 PM
drdoug75's Avatar
drdoug75
Default Washer Fluid DIC
Ok I have fixed all my tires with a magnet. But can't fix the damn window washer fluid code. Went to napa and they say there is no new sensor???? Is there an easy way to replace the sensor and fix it. My washer fluid isn't low!
Old Nov 26, 2004 | 07:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would remove the sensor and clean it. Make sure the plug in good shape and the pins are clean and straight. While it is out dip ir in a bucket of water and see if you can get it to clear!
BC
