2000 antenna inoperable
Old Nov 26, 2004 | 03:34 PM
Marathon26's Avatar
Marathon26
Default 2000 antenna inoperable
The antenna will not fully retract on my 2000 vert. It will go up all the way, but only goes down about 1/2. I can push it the rest of the way with relative ease. I tired the fix shown in 2000: Service Bulletin: Power Antenna Not Working Properly or is Completely Inoperative. I replaced the )-ring Assembly/Cap Nut as suggested, but that did not cure the problem. The owner's manual indicates there is a kit that may cure the problem. Has anyone experienced this problem and what did you do to fix it?
Old Nov 27, 2004 | 12:35 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
We had that problem back in 00. The fix was simple, clean the antenna shafts with mineral spirts on a regular basis.
Old Nov 27, 2004 | 07:06 PM
Marathon26's Avatar
Marathon26
I give that a try. I tried WD40 without any luck.
Old Nov 27, 2004 | 07:07 PM
Marathon26's Avatar
Marathon26
I'll give that a try. I tried WD40 without any luck.
To 2000 antenna inoperable
