Radiator plug
Old Nov 26, 2004 | 06:08 PM
robbber's Avatar
robbber
Default Radiator plug
Can anyone please tell me where the radiator plug is and how to get it out. I want to drain the coolant and need to get the plug out. I have a '97. thank you,
Robber
Old Nov 26, 2004 | 06:30 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
bottom corner passenger side...depending on design you either twist and turn or you need a hex head wrench..don't recall the size...but you need to get under there to see it..its hard to find just feeling around..
Old Nov 26, 2004 | 07:37 PM
C5inWV's Avatar
C5inWV
Be patient when loosening the plug. Get the car in the air so you can see what you're doing. Mine is a '97, and I damaged the shroud around the plug while trying to reach up out of sight. It has been repaired, but it added to the effort.
The drain plug on the newer ones are different; I think the hex nut design started in '99 or 2000.
To Radiator plug
