How do you test the coils?
Old Nov 29, 2004 | 09:26 AM
SmoothFRC's Avatar
SmoothFRC
Default How do you test the coils?
My buddy has the same year c5 as me and he has had 2 coils go bad and 1 may have been bad for a while...
Is there a way to test the coils to make sure they are putting out the right amount of volts?
Old Nov 29, 2004 | 09:29 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Wheres Bill C or Patches....
Old Nov 29, 2004 | 01:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Right here where I always am! Most of the auto parts stores sells a calibrated spark tester. It's a spark plug with a shield around it and a measured gap. You plug it in to the spark plug wire and attach the ground wire to the vehicle ground and turn the engine over.
I do the same thing with two phillps screw drivers. Stick one in the boot and bridge the other one from ground. I vary the gap to see how far the spark will jump and how intense the blue color is! Usually get a good 3/4 of an inch jump! Oh by the way,,,dont get zapped!
There are some resistance readings that you can take to see if the primary and secondary internal windings are good. I am at work so I can not provide them to you until later to night. Some coils also can have a bad exterior plastic coating and can arc to the valve covers or the coil electrical plug!
Before I would suspect a bad coil, I would be looking at the wires and plugs. There cheap and easy to replace. OEM wires should read 250-750 ohms end to end and have no nicks,cuts or tears in the boots or wires. Also inspect the terminals inside the boots and make sure they are not GREEN with corrosion!
Here are some pictures of problems that i found on my ZO6.
Here are a few of the things that I found after I had my headers installed. I had the poping and dead miss under load (moderate to full throttle) and loss of power.
[IMG][/IMG]
[IMG][/IMG] [IMG][/IMG]
The spark plug was the main issue!
[IMG][/IMG]
[IMG][/IMG]
Thats about it for secondary ignition info
Old Nov 29, 2004 | 04:23 PM
sempi's Avatar
sempi
Default Mr. Bill
Good info, as I have a plug that could be an identical twin to yours.
Anyway, back to the important stuff. Exactly where do you get your nails done? Nice ring, too. J/K
Sempi
Old Nov 29, 2004 | 05:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats the 25th Anniversary ring. Almost as much as the ZO6! The wife says thanks!!
Just let me know if you need any more help.
BC
Old Nov 29, 2004 | 05:23 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I started getting a poppnig at WOT... then I found a plug wire not fully seated... bam problem fixed.
Old Nov 29, 2004 | 10:12 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I use a timing light and watch the strobe... if it is a nice steady beat... your coil is firing ok... if it skips a few beats here and there... it needs to be replaced. I had a bad coil for 3 years and 4 dealerships couldnt find the problem... the coil was it and thats how we found it.
VR
To How do you test the coils?
