Added Dynatech long tubes, results within.
Old Dec 2, 2004 | 06:47 PM
T_Vert's Avatar
T_Vert
my 00 didnt have pup cats either,.
dave
Old Dec 3, 2004 | 04:04 AM
blackbelt's Avatar
blackbelt
i though pup cats didn't appeat till 01 I could be wrong though
Old Dec 3, 2004 | 04:49 AM
vettenuts's Avatar
vettenuts
Originally Posted by CNB
I have the graphs but there is no file extension so I do not know what program to open them with.
You may need to scan them into a jpeg file. I did that as well as digitized the plots so I would have the digital data to play with too.
Old Dec 3, 2004 | 07:49 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Pup cats didn't appear until 01 unless your car was sold in california.
Add me to the list of those who think your stock dyno was way high. I have a friend with a 2000 FRC with I/E and he made 305rwhp this past weekend.
Old Dec 3, 2004 | 10:01 AM
Heretic's Avatar
Heretic
don't know anything about these headers. However here is a topic with the same headers. He got a whole 2 hp out of the headers????
Something is wrong and people don't seem to like them at all.
http://forums.corvetteforum.com/showthread.php?t=960193
If I was you I would go with LG Headers. Doing it right the first time is always a plus.
This is what I'm talking about.
There is no magic that can make one long tube header outperform another set by 20HP, it just does not happen, unless one set is absolute crap, which the Dynatechs are not.
Old Dec 3, 2004 | 12:19 PM
CNB's Avatar
CNB
Heretic, I understand your point of view when people go off and make a post like that. The verdict is not out yet and I haven't even put the graphs up yet for everyone to see.
Old Dec 3, 2004 | 08:14 PM
Jack Behrle's Avatar
Jack Behrle
My 99 FRC w/Blackwing, Xpipe, stock mufflers and an MAF-T pulled 326hp/330torque after four pulls on the dyno. Used the MAF-T to fine tune the WOT mixture strength, timing and added 10 hp (to 326)
Logging w/Autotap showed the LTFT to be optimal at -.885 with O2 sensors reading midway between lean and rich.
I think the 99 and 2000 FRC have good potential with realtively minor mods.
Old Dec 3, 2004 | 08:58 PM
CNB's Avatar
CNB
For some reason I could not get my highest pre-header dyno graph but this is close enough. Here is the horsepower/torque graph.
Red is before and blue is after.
Old Dec 3, 2004 | 09:00 PM
CNB's Avatar
CNB
Here is a graph of the air/fuel mixture.
Old Dec 3, 2004 | 09:02 PM
CNB's Avatar
CNB
Like I said before the conditions were almost exactly the same and the same dyno.
Old Dec 3, 2004 | 09:56 PM
vettenuts's Avatar
vettenuts
Your stock curve, at about 4,200 RPM looks like it had some spark knock and the timing was taken out. Also, the headers seem to be losing it at the upper RPM with the curve sloping down. Mine is flat in that area of the curve, as your stock curve is. Looks like about a 15 HP gain at 4,700 RPM. Your stock curve is to some degree like mine was, and doesn't show much gain down low. But I had awful spark knock and it was killing me once it started. You seem to be a little on the lean side in the upper RPM range as well, at least according to the tuner I used. And it appears to be quite lean between 3K and 4K RPM.
Old Dec 3, 2004 | 10:32 PM
CNB's Avatar
CNB
I noticed the air/fuel is messed up. It is lean and should be much more flat. I think the guy who did my tune did a half *** job. I'm having my original tuner look at it tomorrow. It will be interesting to see what he says. I wish I had gone to him first but I could not get ahold of him.
Old Dec 4, 2004 | 07:27 AM
  #33
vettenuts's Avatar
vettenuts
Good luck, if you do get a re-tune it would be interesting to plot the new tune against the other two so we can see what changes. Hope everything goes OK
Old Dec 4, 2004 | 10:35 AM
  #34
Irish Whiskey's Avatar
Irish Whiskey
Have '00, A4 coupe: blackwing and bridge: corsa indy's & x-pipe: 3.42 diff with hardened shaft. That's it: RwHp: 304 hp:
Will be adding Kook's 1 3/4 into x-pipe + high-flow cats assembly feeding through the corsa's. Will see what it does with and without tune.
Old Dec 4, 2004 | 02:13 PM
  #35
RogueVette's Avatar
RogueVette
And yet you have another friend who dyno'd signifigantly more then that on a 99 with I/E and the trap speeds to back it up
Old Dec 4, 2004 | 04:45 PM
  #36
CNB's Avatar
CNB
I had the tune looked at today by my original tuner (different guy who did not do the header tune) and apparently it was a crappy tune. I have corrected that and will try to get to the dyno soon.
Old Dec 4, 2004 | 06:51 PM
  #37
vettenuts's Avatar
vettenuts
Did your original tuner make some changes? How does the SOTP feel?
To Added Dynatech long tubes, results within.
Old Dec 4, 2004 | 07:31 PM
  #38
CNB's Avatar
CNB
He made a lot of changes. Part throttle response is much better. He also replaced my idle tables from 2001 & up. He did pull some timing so it is now at 26* instead of 28*. He changed fuel delivery and a few other things. Today was warmer then the last time I drove the car so wot seemed about the same. Torque feels stronger then before. I wonder what the dyno will show.
Old Dec 4, 2004 | 08:35 PM
  #39
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Ah, so he pulled some timing?
Better than that original tuner's 1hp gain, I would be willing to bet.
Old Dec 4, 2004 | 10:57 PM
  #40
CNB's Avatar
CNB
What's your prediction?
