oil pump porting and blueprinting
Old Dec 3, 2004 | 10:06 PM
Monks's Avatar
Monks
Default oil pump porting and blueprinting
Where is a good place to get a new oil pump ported and
blueprinted, and how much will that cost?
Thanks!
Old Dec 4, 2004 | 09:41 AM
Monks's Avatar
Monks
Ttt
Old Dec 4, 2004 | 09:51 AM
Suprfun's Avatar
Suprfun
Old Dec 4, 2004 | 01:33 PM
leaftye's Avatar
leaftye
Lately the guys on ls1tech.com don't think the porting does anything. I know in theory it does, but in practice it seems like a waste of money. You didn't mention "ls6" anywhere, so it seems like you haven't been fooled by marketing tactics....all the new oil pumps in the ls1/ls6 are the same. If you want higher oil pressure, go ahead and shim it, and definitely install a new o-ring. Shimming it might be waste. Seems like a lot of people think oil pressure above 40 psi is excessive, doesn't make anything better, and would suck extra hp away. You can get the oil pump and o-ring on www.gmpartsdirect.com for around $80. FWIW, I'm getting a new oil pump from gmpartsdirect and I don't plan on shimming it. I already have an oil cooler, and eventually I'll have an Accusump. Basically I'm saying I care a lot about making sure my oiling system works probably, and I don't think a ported and shimmed pump is worth the hassle or money.
Old Dec 4, 2004 | 03:28 PM
Chris@AP-Engineering's Avatar
We sell two versions of the oil pumps:
Ported & Prepped - $125.00
Ported, Prepped & Coated - $155.00
They are just good insurance and you can also shim them to get higher oil pressure. Our's come unshimmed.
Give us a call if you need one.
To oil pump porting and blueprinting
