Maximum Speed 80mph
Old Dec 5, 2004 | 02:15 PM
BAMA999's Avatar
BAMA999
Cruising
Default Maximum Speed 80mph
After installing new transmission in car, I'm getting "maximum speed 80mph; shocks inoperative; service ride control". Any response that might help me would be greatly appreciated. UPDATE!!!!
After putting car on rack, I found that the wire going into plastic piece that screws into shock was broken. It seems that it was not disconnected before dropping rear end. If anyone has or knows where I can find the piece that runs from the frame and screws into the shock, my life would be a lot better. The dealership wants me to purchase a whole shock at 655+. Thanks in advance. It is the right rear shock (F45) that is the problem.
Old Dec 5, 2004 | 02:49 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
try clearing the codes...
Old Dec 5, 2004 | 05:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please clear the codes and see if it comes back. Looks like they didnt hook something back up correctly.
Here is how to check codes:
The IPC display, the 20-character, vacuum florescent screen above the steering column that says "Corvette by Chevrolet" every time you turn on the key, is a powerful device. DIY Service Techs are going to be most interested in the IPC's ability to show diagnostic trouble codes (DTC) for all the modules that transmit them.
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-second period.
Inititially, the on-board diagnostics go into the "automatic" mode which shows each module's DTCs in a pre-set sequence:
· 10 PCM Powertrain Control Module page 6-357 - 6-361
· 28 TCS Traction Control system ABS on page 5-86
· ?? RTD Real Time damping page 3-136 (I do not have this option)
· 40 BCM Body Control Module page 8-405 UTD Page 8-727
· 60 IPC Instrument Panel Cluster page 8-508
· 80 radio page 8-213
· 99 HVAC Heater Vent-Air Conditioning page 1-118
· A0 LDCM Left Door Control module page 8-904 to 8-951
· A1 RDCM Right Door Control Module page 8-904 to 8-951
· AC SCM Seat Control module page 8-1064 -8-1082
· B0 RFA Remote Function Actuation page 8-676
For each module, all DTCs will be displayed. If none are present in a module, you will see "no more codes" on the ICP display.
There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem, now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction. "Intermittents" are the most challenging DTCs. An intermittent may have happened only once, may have happened more than once but is inconsistent in its appearance or may be happening on a regular basis but not at the time the IPC is displaying codes. History codes can also be caused by a current malfunction in a system that is not operating at the time DTCs are displayed. An example is the rear window defogger which doesn¹t operate until the BCM detects engine rpm. For history codes set by a system that does not operate with the key on and engine off, a special diagnostic tool called a "scan tester" is necessary to properly diagnose the malfunction.
Once the IPC has displayed all 11 modules, the system goes into the manual mode which allows selection of each module using combinations of DIC buttons. The manual mode can also be entered at any time during the automatic sequence by pressing any button except "E/M". Once the IPC displays "manual diagnostics," you may select a particular module by pressing the "options" button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" to move forward or "fuel" to go back.
To exit the diagnostic mode at any time, press "E/M". If you want to erase or "clear" codes, press "reset." Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory.
· 10 PCM Powertrain Control Module page 6-357 - 6-361 Domestic
· A=DTC set immediately and MIL is turned on
· B=MIL turned on after 2 consecutive drive trips
· C=After one failure and stored in History MIL not turned on
Old Dec 5, 2004 | 06:43 PM
David426's Avatar
David426
You should not be going over 80mph anyway, this is against the law. I can't believe a vette owner would be doing this kind of thing.... Just kidding. Hope Mr Curlee has solved your problem. This man is a great asset to this forum..
Old Dec 5, 2004 | 07:55 PM
XXX Vette's Avatar
XXX Vette
I have the F45 shock option in way 97, I replaced the shocks with Bilsteins and I am getting the same massage.
Old Dec 5, 2004 | 08:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you disable the shocks you will get codes and messages. You can find someone with a GM TECH II and have that option turned OFF and the codes will go away! I strongly recommend doing that!
BC
Old Dec 5, 2004 | 09:10 PM
Dr. Dan's Avatar
Dr. Dan
My first thought when seeing the title was shift into 3rd gear.
...but hope that you get it resolved.
Old Dec 6, 2004 | 08:35 AM
XXX Vette's Avatar
XXX Vette
My local chevy dealer said, they tryed to turn off he F45 option but was unsuccessful. Someone on this forum said to unhook the F45 computer in the rear l/h corner compartment then turn off the option, I have not been back to the dealer since I unhook it.
Old Dec 6, 2004 | 08:37 AM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Old Dec 6, 2004 | 09:20 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
If your dealership cant turn it off... you can buy the kit from LAPD that plugs into each shock wire and takes care of the problem. Contact them directly for info.
VR
Old Dec 6, 2004 | 09:22 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
One of the local chevy dealers told me that it was impossible to install Tire pressure sensors on an 02 ZO6! I went to another dealer and I have them on my 02 and they function PERFECTLY!
Some dealers dont know mr Goodwrench from Adam!
Bill
To Maximum Speed 80mph
