Coyds timing chains?
Old Dec 6, 2004 | 07:31 PM
Monks's Avatar
Monks
Default Coyds timing chains?
I have a new shortblock that I bought without a cam.
I have a Cam gear with "Hex-adjust" stamped on it. I assume
it is a Cloyds single roller. The timing set is new, but the chain
looks "wimpy". Are the Cloyds single chain any good, or should
I spend the money and install a good double roller?
Thanks!
Russ
Old Dec 6, 2004 | 08:16 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
For 130.00 you can get a nice Rollmaster double roller. Excellent upgrade!
Old Dec 6, 2004 | 09:05 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Hex-A-Just is a Cloyes set. The button is great for degreeing a cam. It is a heavy duty chain. I used the same to degree in my cam (asymmetrical lobes - I thought it would be a good idea to degree it in).
Here is an add from a large Performance Center in the Great State of Texas:
Cloyes LS1 Heavy Duty Timing Set
Price: $329.95
Description:
This Cloyes heavy duty timing set replaces the stock LS1 timing set for added strength and durability. Hex-A-Just system provides accurate timing adjustments for tuning.
To Coyds timing chains?
