HELP!HELP! Diff Change Have Question
Old Dec 7, 2004 | 06:36 PM
ANTHONYCORVETTE's Avatar
ANTHONYCORVETTE
Default HELP!HELP! Diff Change Have Question
HAVE A 98 A5 WITH A 273 AND AM TRYING TO CONVERT TO 342 (2003) Z06 DIFF. DO YOU HAVE TO DROP TRANS AND EXHAUST IF YOU ARE ONLY CHANGING DIFF. IS THERE ENOUGH ROOM TO LOWER TRANS AN INCH OR TWO IN ORDER TO CLEAR THE DIFF AND TRANS SHAFT AND REMOVE DIFF FROM CAR. IF NOT DO YOU HAVE TO REMOVE EXHAUST AND DRIVESHAFT TUBE COVER PLATE(LONG FLAT PLATE WITH MANY SCREWS) IN ORDER TO LOWER/ANGLE TRANS/TUBE /ENGINE IN ORDER TO GET ROOM TO REMOVE DIFF....ANY THOUGHTS...KEVIN
Old Dec 7, 2004 | 06:46 PM
Patches's Avatar
Patches
You need to remove the center and rear sections of the exhaust, the rear crossmember and the tunnel plate to get the diff out. A couple of guys have posted in the past that they tilted the engine/torque tube/tranny/diff combo enough to slide the diff off without pulling the tube/tranny/diff combo out. I've helped with a diff swap and, this weekend, helped with a clutch swap and both times we pulled the assembly completely out.
You'll notice a sticker on the torque tube that warns against tilting the engine/torque tube/tranny/diff combo below the bottom of the rear tub or you'll crush the firewall. Also, you'll need to disconnect the intake so it isn't damaged or doesn't resist tilting. Here are a few pages of pics of the diff removal we did.
http://redshift.homestead.com/Drivetrain1.html
Here's a shot of the sticker. The warning's in the manual as well.
Old Dec 7, 2004 | 07:14 PM
ANTHONYCORVETTE
Default Diff Removel
WHEN YOU SAY DISCONNECT INTAKE DO YOU MEAN REMOVE!!!
OR HAVE YOU BEEN ABLE TO TILT TO AN ANGLE TO CLEAR AND WATCH FIREWALL/INTAKE CLEARANCE CLOSELY!!!
Old Dec 7, 2004 | 07:19 PM
Patches's Avatar
Patches
Disconnect the airbridge, the tube coming from the MAF that has the accordion rear section that goes to the throttle body. Leave the intake manifold on.
Old Dec 7, 2004 | 07:40 PM
ANTHONYCORVETTE
Default Diff Removal
I,ll Try Er...just Trying To Get OuT Of Complete Exh And Tunnel Pan Removel...
Old Dec 7, 2004 | 07:47 PM
Dope's Avatar
Dope
Resident moron
You can't get out of it. You need to lower the drivetrain wayyyyy further than the tunnel plate will allow you.
Dope
Old Dec 7, 2004 | 07:51 PM
see5's Avatar
see5
You do not have to pull the trans or fool with interior but never heard of leaving the tunnel plate in. Just tilt the drive line slowly and only barely enough to get the dif clear.
Old Dec 7, 2004 | 08:01 PM
Dope's Avatar
Dope
Resident moron
Btw, read this: http://fear.net/~dope/c5_rear_install_nopics.html
Dope
Old Dec 7, 2004 | 08:20 PM
ANTHONYCORVETTE
Default Diff Help
I APPRECIATE ALL THE HELP AND PICTURES. ONE MORE QUESTION DO YOU NEED TO REPLACE SEALS ON NEW DIFF. THE ONE I AM PUTTING IN IS A 342 OUT OF A 2003 Z06 WITH ROUGHLY 1K MILES....AGAIN THANKS FOR ALL THE HELP IN ADVANCE....KEVIN
Old Dec 7, 2004 | 08:27 PM
Shylor's Avatar
Shylor
Please don't use upper caps in your post. It's like yelling.
Dope's Avatar
Dope
Resident moron
Nope, no need unless the big o-ring that's on the end of the tranny is ripped/ruined in some way.
Dope
Old Dec 7, 2004 | 08:32 PM
Mike Mercury's Avatar
Mike Mercury
don't forget to transfer over the "seal plate" from your 2.73 to the 3.42
Old Dec 8, 2004 | 01:31 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
You don't need to remove your center exhaust or your tunnel plate. You can brace your tranny and diff up and then drop the rear suspension. Take the bolts out that connect the tranny and diff. Take the side cover off your diff and turn it. It will slide right off. If you are doing this instal on jack stands then this way probably not work. Kaley
Old Dec 8, 2004 | 02:16 PM
Mike Mercury
I'm trying to picture this approach. Are you saying one doesn't need to swing down the torque tube/tranny assembly ? That by solely dropping the rear suspension - there will be enough clearance ???
Old Dec 8, 2004 | 02:30 PM
0Kaley@DragonRace
Supporting Vendor
You will have to drop the tranny enough to where there is only about an 1/8th between the tourque tube and the plate. Then there will be enough clearance. You have to take the side of the diff off and spin it. It will give you enough room to pull it out. Kaley
Old Dec 8, 2004 | 03:17 PM
Dope's Avatar
Dope
Resident moron
Interesting approach. Sounds easier.
Which side do you take off?
Dope
Old Dec 8, 2004 | 03:46 PM
Mike Mercury
You will have to drop the tranny enough to where there is only about an 1/8th between the tourque tube and the plate. Then there will be enough clearance.=
OK - I see it now. So you do still need to swing down the assembly - but there is enough existing clearance (without taking off the exhaust/tunnel cover).
Help me here... why does the carrier side plate need removed ?
To HELP!HELP! Diff Change Have Question
Old Dec 8, 2004 | 03:57 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
When i removed my tranny and diff.....a M12 tranny, i just braced the drivetrain dropped the rear suspension then un bolted the transmission from the torque tube, slid it back disconected the shift linkage, and lowered the tranny, it came out of the car with no problems or without having to touch the exhaust or the torquetube
Old Dec 8, 2004 | 04:29 PM
Dope's Avatar
Dope
Resident moron
It seems there isn't enough room if you don't. You take off a side plate, rotate the carrier 90* so that the 'empty' side is now facing up, and you should be able to slide it off.
Seems plausible. Seems useful too. Getting the exhaust lined back up every time gets old FAST.
Dope
Old Dec 8, 2004 | 04:49 PM
chriskaw7r's Avatar
chriskaw7r
Dope
I hear yah there brother real BS in my opinion
