1st Corvette
Old Dec 8, 2004 | 01:15 PM
CKWHEELES's Avatar
CKWHEELES
Default 1st Corvette
About A Moth Ago I Purchased A Red 99' C5, With 35k Miles On It. Over The Last Couple Of Weekes My A/c Has Stoped Working. I Think This Is Due To The Exterior Temprature Reading To Low. Is There A Way To Reset This? Also I've Purchased An Aftermarket Shift Knod For The Stock Shifter. How Do I Get The Stock **** Off. Is There A Set Screw Or Something I Need To Remove First? Lastley Are There Any Genaral Maintenace Items To Take Care Of, Besides Oil And The Air Filter?
Old Dec 8, 2004 | 01:20 PM
C5dream's Avatar
C5dream
Go here for help with the shift ****. https://www.corvetteforum.com/techti...D=34&TopicID=1
Old Dec 8, 2004 | 10:33 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
On a 6 year old car I would change the following fluids.
Engine oil
Tranny
Coolant
Brake
Power Steering
Rear Diff.
in other words, all fluids.
Old Dec 9, 2004 | 12:10 AM
red97vette's Avatar
red97vette
Old Dec 9, 2004 | 08:35 AM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Engine oil
Tranny
Coolant
Brake
Power Steering
Rear Diff.
Also, welcome to the joys of Vette ownership. Don't forget to wave
Old Dec 9, 2004 | 09:01 AM
RCK1999's Avatar
RCK1999
If your exterior temperature reading is wrong, most likely your outside ambient air temp sensor is bad. Its about an $8 part and is really easy to change. The sensor is located at the very bottom left-hand side of the rediator shroud. Easiest way to see it is to look up under the left front of the radiator and you will see a little plastic tip sticking through the shroud. Its just an "unplug the old, plug in the new" repair. It is a little tight to get your hands on the sensor. Also, the connector that the sensor plugs into may be corroded beyond help. It sort of a pain to replace the connector as you need a new one and splice it into the wires.
I would try the $8 sensor first.
Old Dec 9, 2004 | 09:05 AM
Morzoff's Avatar
Morzoff
All of the above, and congrat's on the new ride
To 1st Corvette
