Replacing factory fog light
Old Dec 9, 2004 | 07:02 PM
sid459's Avatar
sid459
Default Replacing factory fog light
Can anyone please explain to me how to change the fog light bulbs on a 1999 coupe. I got a bulb out and cant figure out how to take it out
Old Dec 9, 2004 | 07:52 PM
wwashing's Avatar
wwashing
Raise the head-lights. Either use the *****, or turn the lights to on then back to park.
Remove the plastc shroud that's on the head light module.
(Assume it's the driver's side light that you want to replace.) Sit on the front facia/bumper or lean back against it and reach down under the headlight with your left hand until you locate the fog light unit.
Grasp the bulb fixture that's inserted in the back of the light fixture and twist it to the left and pul.
Replace the bulb and repeat the procedure in reverse.
Old Dec 9, 2004 | 08:03 PM
ANTIVINUM's Avatar
ANTIVINUM
There are two ways to go about this. One is you can open the hood and snake your hand down behind the fog light and take it out. Or two you can remove the underpinning under the bumper I think they are 7mm screws and you should be able to see the back of the fog light. The bulbs just twist out. Just be sure that you do not touch the new bulbs with your hands or bump the bulb up against anything.
Old Dec 9, 2004 | 10:57 PM
ALLEGRO's Avatar
ALLEGRO
Both ways work.
Old Dec 10, 2004 | 09:07 AM
VetteSiNz's Avatar
VetteSiNz
I use these procedure ...easy!
To Replacing factory fog light
