disabling torque management harmful?
Old Dec 9, 2004 | 07:39 PM
greg_nate's Avatar
greg_nate
Default disabling torque management harmful?
I am getting ready to do some mods to my '40 A4, and it was advised by someone that disabling torque management would be harmful to the tranny...that it is there for protection.
Yet, I've read in other places that disabling torque management, and speeding up the shift times actually *improves* the longevity/durability of the tranny. My mods should put the engine at about 450hp at the flywheel.
I am wondering if I could get a definitive answer on tgransmission programming - whether it is harmful to the tranny or not.
Thanks in advance
greg (newbie vette owner, newbie forum poster)
Old Dec 9, 2004 | 07:49 PM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
Old Dec 9, 2004 | 07:54 PM
C5JONNY's Avatar
C5JONNY
your tranny isnt going to make it with 450hp whether you disable it or not. Deleting TQ managment will grenade your tranny even faster. Its there to begin with because the 4l60e can barley handle the power the stock vette puts out.
Old Dec 9, 2004 | 08:41 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Your stock 4L60E can barely handle whats on it's plate anyway. 450 RWHP will kill your stock tranny sooner rather than later if you beat on it.. If you are going to put down that much power, you'll need to have a built transmisssion anyway.
Old Dec 9, 2004 | 11:41 PM
yankeevetteconvert's Avatar
yankeevetteconvert
I think his post said 450HP at the engine.That will only give him 360 Hp at the rear(using a 20% driveline loss).That is still a lot of power for the A4 to handle but much more mangable than 450 HP.I would go with the stock trans and eliminate TM. When the trans goes and it will eventually you can have it rebuilt with parts that can handle the 360 HP.
Old Dec 10, 2004 | 12:28 AM
LS1LT1's Avatar
LS1LT1
I agree...the 4L60E is not that bad at all...it's a great automatic, very strong, smooth and performance oriented at least when behind a stock or mild bolt on motor so I think it can handle it if it's in good shape/lower miles.
Maybe doing a tranny cooler and new fluid, filter and gasket would help.
Old Dec 10, 2004 | 04:29 AM
greg_nate's Avatar
greg_nate
Thanks for the good feedback. I looked at both of your profiles, and noticed that you both actually have A4s, with mods. I am wondering how long they lasted for you, and what kind of rebuild you did on them.
I like the idea of postponing the inevitible with a cooler and new fluid. I've read (again, research through the internet) that some synthetic fluids can keep the temperature down by as much as 30 degrees.
Old Dec 10, 2004 | 08:13 AM
C5JONNY's Avatar
C5JONNY
23,000 miles and approximatey 35 1/4 mile passes and my tranny is smoked. I have a cam only package that dynos 355 to the wheels. sy3500 TC, and 3.73's also have a tranny cooler. Im currently about to start the rebuild.
Old Dec 10, 2004 | 09:02 AM
C5XTASY's Avatar
C5XTASY
A good price on a tranny cooler for a C5 is about $900 for parts alone. I about fell over when I saw that. By the time you get done with the install, it may be worth just getting the A4 upgraded instead. Something to think about anyway.
Ed
Old Dec 10, 2004 | 10:19 AM
C5JONNY's Avatar
C5JONNY
Ed
no, my b&m tranny cooler was $50.00
Old Dec 10, 2004 | 10:33 AM
Mike Mercury's Avatar
Mike Mercury
sure it is. When you buy a sports car and continue to mod it... things will break.
It's a risk we all take.
Old Dec 10, 2004 | 02:04 PM
C5XTASY's Avatar
C5XTASY
The tuners I talked to, and the FredBeans dealership, all quoted $900 for the parts. Of course this includes all stainlees lines, etc. They told me I probably wouldn't want to run rubber lines that distance. Who knows?
Ed
Old Dec 10, 2004 | 03:09 PM
'06 Quicksilver Z06
I paid less than $100.00 for my Haden transmission cooler. Are you perhaps referring to the transmission cooler for the MN6 equipped cars?
http://www.gmpartsdirect.com/results...umber=12480080
Old Dec 10, 2004 | 03:28 PM
C5XTASY's Avatar
C5XTASY
I wasn't intentionally referring to it, but I must have been! I about picked myself up of the floor when the price was quoted. The tuners, and the parts fella from FredBeans, all knew I had an A4 though. On your Haden, are the lines rubber (or fabric) and are they in any danger of contacting anything? I've always been a believer in transmission coolers, but not at almost the cost of a new transmission.
Thanks!
Ed
Old Dec 10, 2004 | 03:52 PM
'06 Quicksilver Z06
Rubber and in no danger of contacting anything.
Old Dec 10, 2004 | 03:56 PM
yankeevetteconvert
I have 37,000 miles on mine but only 10,000 miles and 12 trips down the strip with the SS3600 TC.I have a B&M tranny cooler and my trans temps are always below 200*.It only cost $60 and is realy worth the money.I did make about 30 more runs at the track with the stock TC.I have not rebuilt the tranny yet.
Old Dec 10, 2004 | 05:05 PM
Vector's Avatar
Vector
I've added a tranny cooler as well. 2800TC, 3.42 gears, 394RWHP, 361RWTQ - 35K miles but only about 4K since the serious power (H/C) and TC was added. The jury is still out if my stock A4 will hold up. About 15 passes down the 1/4 miles track with drag radials and so far so good. When it goes, and I fully expect it will, it will be a beefed up tranny and bye-bye to the torque mgt. system.
Old Dec 10, 2004 | 05:41 PM
Rays Vet's Avatar
Rays Vet
I have about 13 passes down the 1/4 with t.q. management completely eliminated.343 rwhp and 3200 stall and still going strong.
To disabling torque management harmful?
