Torque Converter Question
Old Dec 11, 2004 | 11:35 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Torque Converter Question
What are some of the preferred brands for c5 torque converters? Are the gains noticable without other driveline modifications on an A4? Also, how easy is the install? Thanks a lot.
Old Dec 11, 2004 | 11:49 AM
Mitch C's Avatar
Mitch C
Yank is by far the most popular brand with C5 owners. With Vig being second most popular. What exactly do you mean by other driveline mods? If you are comparing a C5 to what has to be done to an f body to get it to launch, nothing really has to be done to a C5s rear suspension to get good performance. Because the tranny is located in the rear swapping converters is more involved than on an F Body. If you don't have a lift I would not tackled the job.
Old Dec 11, 2004 | 12:07 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
any ideas as to the estimated labor costs?
Old Dec 11, 2004 | 12:16 PM
Mitch C's Avatar
Mitch C
I paid 500.00 to swap my T/C & rear end. Figure from 300.00-400.00 to swap just the T/C.
Old Dec 11, 2004 | 12:34 PM
JSTAN's Avatar
JSTAN
I bought a used SY3500 from a CF member for $450 bucks. When I installed the converter I also installed the following:
Transgo shift kit - $100.
Used 3.42's from another CF member for $800
Tranny Cooler $30
LS1 edit - $450
New Seals and Gaskets for 3.42's - $200
Tranny and diff fluid - $100
I installed everything myself so labor was free. I would assume a shop may charge you just for the converter swap maybe $500 - $700 and maybe another $100 - $300 if the transgo shif kit, tranny cooler install and gear swap for labor.
Plus you could recoupe some of the cost if you sold your old gears, specifically if the are 3.15's. I sold mine for $350.
The differnence in how the car drives is night and day. I have taken it to the track and my best time is 12.8@109 using those crappy run flats. I see you live in Springfield, I live in Millis MA. If I had my car still on the road I would give you a ride so you could feel the difference.
Old Dec 12, 2004 | 07:58 AM
kirbyloid's Avatar
kirbyloid
Default Tc
I had a Yank SS3200 installed at the same time as 3.73 gears, the combination is great. I would however suggest removing Torque Management if you go the route I did it really made a difference in the feel of the TC after I removed it. I would suggest though no matter what you choose find someone that has a car setup like you want and take a ride, always welcome to ride in mine if you find yourself in the area.
Good Luck, Kirby
Old Dec 12, 2004 | 09:27 AM
Mike04's Avatar
Mike04
Yank and Vigilante are popular. I highly recommend you ride with someone who has the TC you are thinking about first, you may or may not like it.
I would look into haveing your torque management removed. The difference in the low end response and the shifts are huge!
Old Dec 13, 2004 | 12:02 AM
Face's Avatar
Face
Yank seems to be the most popular. Gains can be mild to wild depending on the stall and STR you go with. You can expect anywhere from a .3 to .7 reduction in E.T. at the track depending on which converter and your other mods.
Old Dec 13, 2004 | 09:19 AM
IMQUIK's Avatar
IMQUIK
Love my Yank SS-3600!
To Torque Converter Question
