Anybody had trouble with their headlamps 'shaking'.
I am able to move my L/F up and down about a 1/4 inch when open.
while driving it shakes.
I've adjusted the actuator , and tightened all the bolts (I think)
I had to replace an adjuster once because the square plastic piece was loose.
Have you pulled the plastic off and checked the pivot and the arms the actuate the lamp ?
The adjusting screw to the headlight frame has a small square piece that snaps into the metal frame that the headlight attaches to. there are 3 of them. one on the adjuster that controls side to side and 2 opposite of that.
also there are some white tabs that can be adjusted for the whole headlight assy.
I wish I could find a pic.
ya got one ?
