Z06 Cam Upgrade
TR 224/224 .563/.563 114
TSP 224/224 .581/.581 114
TSP 225/225 .589/.589 114
FMS FM4 226/226 .575/.575 114
TR 224/227 .563/.569 114
FMS FM5 224/228 .588/.576 114
Other upgrades include an intake, long tube 1.75" headers, and an underdrive pulley. I will be keeping my cats.
The application is mostly street driving with the occasional track based roadracing driver's ed event. In other words, I want a cam that has torque everywhere (2000-6600 rpm).
I also want to be able to pass a sniffer test and get reasonable mileage out of a set of springs.
- What cam would be best?
- How many miles would I get on a set of springs?
- What would be the estimated RWHP and RWTQ?
Of the cams you mentioned I would go with the FM4 because it is big enoungh to give you a meaningfull increase over your 02 Z06 cam. Alan Futrals cams are known to make great power and to have excellent street manners. Plus it has a moderate lift that should not be too hard on valve springs.
If I were you I would invest in a very good set of dual springs such as Patroit Golds or Comp 921s.
You definately need headers to get the max out of the cam.
You might also want to consider the FM10 228/228 581/581 114
With long tubes and an automatic w/3.42 gears I got 412 RWHP ant 390RWTQ.
With the stick you would do about 430RWHP. It idles a bit rough but not
too bad. Would idle smooter with the stick. I like it a lot. Power everywhere.
The tune on it makes it good as far as a daily driver but thats not what my car is. Its a play toy that I drive a few times a month
That being said I would recommend the FM5
