Looking for 12v for a Flameball....
Old Dec 12, 2004 | 08:08 PM
whitelite's Avatar
whitelite
Default Looking for 12v for a Flameball....
I am hoping to get some expertise for wiring a flameball. Where do I find 12 volts to power the L.E.D. in the shift ****????
Thanks, Randy
Old Dec 12, 2004 | 08:30 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
One 12v supply you can use is in the passenger side foot well fuse panel. It is a switched connection which is what you should use for the shift **** light.
Here's a link to a write up & photos in the Tech Tips section that will show you where it is. (This shows wiring a V1 but will also work for your purpose.)
https://www.corvetteforum.com/techti...=165&TopicID=1
Old Dec 12, 2004 | 09:00 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
I ran mine over to the fog lamp switch, so now it comes on and off with the lights
Old Dec 12, 2004 | 10:07 PM
whitelite's Avatar
whitelite
Thanks guys,
I guess I was hoping for a source under the console, like the trac control button or something like that. Less wire fishing.....
Old Dec 12, 2004 | 10:18 PM
USA-VET's Avatar
USA-VET
Originally Posted by whitelite
Thanks guys,
I used the tc button for my CB install with no issues!
Old Dec 13, 2004 | 12:15 AM
C5 YA's Avatar
C5 YA
Best location is the traction control button. You need to get the ground and 12V switched from this location. It will also dim the flameball w/ the dimmer switch. I believe it's a brown and orange wire.
Old Dec 13, 2004 | 08:13 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It's been awhile but I'm pretty sure the orange wire was power
Old Dec 13, 2004 | 04:50 PM
whitelite's Avatar
whitelite
That's the ticket.......thanks to all!!!
To Looking for 12v for a Flameball....
