Alignment specs needed.........
Old Mar 10, 2005 | 09:20 AM
SDWYZ C5's Avatar
SDWYZ C5
Originally Posted by Richin Chicago
I would like to see more negative camber if you are not on runflats. Close to 1 degree if it is a mixed use car and up to 2 degrees if roadcourses are primary use. 1 degree should be standard from the factory on non runflats.
I agree. I would use more neg camber up to 1. If you go over 1 you will really start to notice inside tire wearing issues but would handle nicely in the twisties. It really depends on your driving style
Old Mar 10, 2005 | 12:45 PM
Dirty Howie's Avatar
Dirty Howie
Thanks Richin and SDWYC C5
I have NON Runflats.
Daily driver. 95% freeway use. The rest is as hard as possible including canyon runs once a week and track 2-3 times per year (hopefully).
I want tires to LAST as long as possible.
Would you still increase negative camber?
So the front Caster and the Toe numbers are OK?
Old Mar 10, 2005 | 02:17 PM
Richin Chicago's Avatar
Richin Chicago
The Z06's came out with -1 as the OEM spec. I'm not sure how much the change would be from what you have now. But my change from 0 to just about -1 was VERY noticeable at high G loads.
Old Mar 10, 2005 | 06:07 PM
Dirty Howie
Rich
Listed below are the alignment parameters from my computer readout. This is from a pretty new Hunter DSP 611 unit.
Camber: -0.2 to -1.2 same for front and rear
Toe: -.06 to +0.14 Front
-0.11 to +0.09 Rear
He has me very close to center line. So Camber of -1.0 would be near the edge.
What do you think? Where is the "factory -1.0" comming from?
Old Mar 10, 2005 | 07:37 PM
SDWYZ C5's Avatar
SDWYZ C5
When you go more neg Camber, go more toe out. The end product is keeping as much rubber on the ground. Freeway driving, you probably do not want alot of neg camber. You will see tire ware. But neg camber is good for the canyons. You have to sacrafice a little to have both.
Old Mar 10, 2005 | 08:02 PM
mountainbiker2's Avatar
mountainbiker2
Hey Howard
The specs look good to me. 95% freeway and you mention that you want the tires to last. As far as neg. camber goes just go test drive your car as hard as you usually do. Then check the arrows on your tires and see where the tire is wearing. Make sure you have about 30psi in your tires. If your wear is at or above the arrows great. If it's below the point by just a little that's okay too. If it's way under the arrow then either you put more air in or get more neg. camber. Your toe is fine, but most racers will toe OUT the front between .12 to .25 Looks like yours is toe in a little. Your rear is fine, but most racers will toe IN as much as .25 and maybe a little more.
My alignment for example.
Front.
-1 Neg camber.
.25 toe out.
Rear.
-3/4 Neg. camber
.25 Toe in.
Tire wear with all hard driving.
3500 miles. Kumho MX.
Old Mar 10, 2005 | 11:06 PM
Richin Chicago
Rich
-0.11 to +0.09 Rear
As far as I know that was the Z06 spec from the factory.
Old Mar 10, 2005 | 11:07 PM
Dirty Howie
Originally Posted by mountainbiker2
Hey Howard
Front.
-1 Neg camber.
.25 toe out.
Rear.
-3/4 Neg. camber
.25 Toe in.
Steve
What freekin arrows are you talking about?? I have the Khumo's and I always run them at 30.
PS..I am a racer....at least in my own mind
Old Mar 11, 2005 | 05:38 PM
mountainbiker2
Steve
Howard
Look real carefull at the sides of your tires where they curve over to the tread. You will see triangles. That's your arrows. I know you are a racer, so what's up with conservative alignment. And the comment "I want my tires to last"
You run your tires at 30psi great. That's cold pressure. Just wanted to make sure you have them set all the same when you go do your test runs. Check your arrows. Let's us know what happens.
Old Mar 11, 2005 | 09:37 PM
Dirty Howie
Howard
Well if I need to look real close I better go get my glasses on......will let you know.
THANKS
Old Mar 11, 2005 | 10:49 PM
David426's Avatar
David426
Wow, what an informative thread for alignment. I still have inner treadwear on my C5. I' dont want any treadwear at all but I don't want to sacrifice too much handling. Is there a happy medium? I have the Goodyear funflats.
Old Mar 12, 2005 | 12:35 AM
SDWYZ C5's Avatar
SDWYZ C5
Good Year runflats need a real conservative alignment. If you try to go even a little bit agressive, you will start to notice tire ware on the inside edges. GY RunFlats have real stiff sidewalls so they will not snug (sit flat) the road like non-runflats would. If you want to go more agressive, start with a little bit of Neg camber but not to much. Stay conservative. If you want more, think about buying a different type of tire. I personally love the Pilot Sports.
It really depends how you plan on driving your car. If you mainly drive on freeways, give up the neg camber so you can keep your tires longer.
Just keep in mind, to much neg camber with GY runflats is a bad thing.
Old Mar 12, 2005 | 12:41 AM
  #33
FiberglassFan's Avatar
FiberglassFan
Originally Posted by Quacker
use this
tire pressure front 34
rear 32
ride ht. front 27-1/8
rear 27-1/2 to 27-3/4
caster front 5.5 deg
rear N/A
camber front -0.7 deg
rear -0.5 deg
toe front 1/64 out each side
rear 0.00
have fun
These specs look pretty good to me. At one time I did a lot of chassis set up for the race shop I hung around in back in my 20s. I had a natural knack for comprehending how all the settings would interrelate and translate to driver descriptions of what a car would do on the track. With nicer weather now I have started to think about alignment to improve turn in. The timing of this thread is PERFECT for me! These numbers look like a nice compromise setup, I will try them out myself soon. Thanks for all the postings! Very educational and informative...timely too.
Old Mar 12, 2005 | 05:46 AM
  #34
Sportsdude's Avatar
Sportsdude
What would you recommend for a c5 with Z06 sway, lowered 25.5 front and 26.5 rear, HAL sports Q1, Conti tires 275/19 F (19x9.5)and 305/20 R (20x11) (I know not a performance tire setup)?
Old Mar 12, 2005 | 07:38 AM
  #35
David426's Avatar
David426
So is the camber (no negative camber) the only spec I need to worry about as far as inside tire wear is concerned?. Or are the other specs too.?
Old Mar 12, 2005 | 09:33 AM
  #36
SDWYZ C5's Avatar
SDWYZ C5
When you adjust your neg camber, you need to play with toe a little bit. Post what you are thinking of doing and we can give you our input. Go ahead and summerize your intended driving style too.
Old Mar 13, 2005 | 01:16 AM
  #37
Dirty Howie
Howard
Steve
I took a little run today. I am wearing exactly right to the point of the little triangles not past.
So I guess I will leave it as is.
Do all tires have these......
To Alignment specs needed.........
Old Mar 14, 2005 | 08:05 PM
  #38
mountainbiker2
Steve
Not sure if all tires have the arrows. I know Kumho and Goodyear supercar and Runflats do.
As your tires wear out, you might go past the arrows a little. That's okay.
Steve
Old Mar 14, 2005 | 08:29 PM
  #39
YO-EL's Avatar
YO-EL
I have a 2000 with NON run flats..
I straight line drive my car only..
No road courses, no twisties, EVER!
Just STRAIGHT line.. (drag race, but I DO drive it 150 miles total to & from the track, when not going 1/4 mile at a time)
What is best for me, regular 2000 alignment specs?
or the Z06 specs?
Old Mar 14, 2005 | 09:57 PM
  #40
SDWYZ C5's Avatar
SDWYZ C5
or the Z06 specs?
Use these #'s from one of my earlier posts...
Factory C5 Alignment Specs
Here is a 2000 C5 Alignment spec right out of my service manual that I just received.
I hope some people may be able to find this info helpful.
Preferred Settings............
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Steering Wheel Angle 0.0 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Thrust Angle 0.0 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
