Alignment specs needed.........
Old May 12, 2010 | 11:10 PM
  #41
tbone106's Avatar
tbone106
Originally Posted by SDWYZ C5
Use these #'s from one of my earlier posts...
Factory C5 Alignment Specs
Here is a 2000 C5 Alignment spec right out of my service manual that I just received.
I hope some people may be able to find this info helpful.
Preferred Settings............
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Steering Wheel Angle 0.0 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Thrust Angle 0.0 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
What would RUN Flats spec be for a 2001?
Old Jun 9, 2010 | 11:00 PM
  #42
tbone106's Avatar
tbone106
Default Just had my alignment done
It's off a hair, pulls ever so slightly to the right (I'm aware of the crown in the road) - should I go back?
The alignment was done on a HUNTER rack to specification.
Old Dec 15, 2011 | 04:38 PM
  #43
Steve.in.Roanoke's Avatar
Steve.in.Roanoke
I realize this is an old thread, but archive & info is very good.
My challenge is I just put new non run flats on the rear, and running good run flats on the front. Prior to new tires handling was fine. Shop tweaked alignment with new tires.
The only way I know to describe it is the handling is "fussy". There's a lot of wheel correcting as I drive two lane winding road 40 miles per day.
I went to another specialty alignment shop & they were very careful on the alignment specs, but... Handling is better but still not right IMHO.
Can anyone shed some light on this for me?
Oops! 2000 convertible w/ less than 50k miles.
