Performance Chips
Old Dec 14, 2004 | 11:53 PM
cjlaw73's Avatar
cjlaw73
Default Performance Chips
Just bought a 99 and I was told that it has a chip. Is it easy to access to see what kind? Don't want to screw anything up.
Old Dec 15, 2004 | 12:05 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
No EPROMs on LS1s, the computer has to be flashed, using a handheld tuner or PC based LS1edit.
Old Dec 15, 2004 | 12:12 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
The "chip" is known as a PCM. It is addressable/programmable, but not plug-in replaceable. To "talk" to it, you need a hand-held tuner (like the Predator or Vinci), or a pc program like LS1 Edit or HP Tuners.
Welcome, and enjoy your vette!
Old Dec 15, 2004 | 12:30 AM
leaftye's Avatar
leaftye
You plug into the car's computer thru the ODBII port below the steering wheel. Real simple, nothing to remove. Not exactly cheap since tuning, really tuning, requires a laptop and $500 in tuning software.
Old Dec 15, 2004 | 05:07 AM
Mitch C's Avatar
Mitch C
Old Dec 15, 2004 | 08:59 AM
Automag928's Avatar
Automag928
Yep...exactly what they said above...No "chip" per se to install...just reflash your current settings via the port under the steering column.
Old Dec 15, 2004 | 11:51 AM
cjlaw73's Avatar
cjlaw73
Default Thanks guys.
New to the performance tuning gig so didn't mean to sound retarded. I bought the car with several aftermarket parts (unknowing to the dealer..ha ha) and was trying to assess the current horsepower. It was easy tracking down a rough figure for bolt-ons like the Borla exhaust but the computer situation was a little tougher. Even more retarded I had it dynoed a month or so ago but didn't realize that the attendant had left the A/C on during the test. Anyone have a guestimate as to how much that would set back the hsp. during the test? Appreciate the help.
Old Dec 15, 2004 | 12:03 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I think with his being a 99 he can get a "chip."
http://www.zip-products.com/Corvette...889542E624B628
Old Dec 15, 2004 | 03:50 PM
99 vett babycar's Avatar
99 vett babycar
that's what he probibly has - you get at it from under the car in the back side of the passenger front wheel well.
Old Dec 15, 2004 | 05:19 PM
ZO6vettepilot's Avatar
ZO6vettepilot
Probably didn't affect the HP/TQ at all. Once the throttle gets past a certain point/RPM or rate of throttle increase, the A/C compressor clutch disengages. However, I believe the fans stay on the high mode, so it may in fact helped very slightly by keeping the coolant temps a few degrees cooler.
Check around on the forums, and you will find that at the strip the guys running the better times leave their A/C on so the fans will run longer.
Z06vettepilot
Old Dec 15, 2004 | 09:10 PM
curtbriggs's Avatar
curtbriggs
I bought a Hypertech, big bucks for a limited change. These suck out the stock program and plug in their program and allow you a few selectable choices, then you might as well throw it away unless you're going to make a huge change in tire size.
I think you get more for your money with a reputable tuner with your car on a real Dyno. Or spend more for the tuning software and laptop, then you can keep up with tuning for each modification, again you're a prisoner to one model year.
I just got the laptop and I'm looking into the yet to be released program that doesn't lock you into a model year like LS1 edit.
Beware, This is MHO from experience, reading and a friend that has LS1 edit and another system that reads A/F ratio.
To Performance Chips
