Oil Psi Stuck At 129!
Old Dec 15, 2004 | 09:08 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default Oil Psi Stuck At 129!
My display reads oil PSI at 129 (80 on the analog) is my sensor out?
Old Dec 15, 2004 | 09:19 AM
runutzzzzz's Avatar
runutzzzzz
Been there done it (Twice)!! Don't be suprised if you change it and it does it again..
Robert
Old Dec 15, 2004 | 10:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Common problem.
Old Dec 15, 2004 | 10:42 AM
Patches's Avatar
Patches
https://www.corvetteforum.com/techti...=246&TopicID=1
Old Dec 15, 2004 | 11:45 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
i think it is the weather change that makes this happen i was in the GM parts dept .And there were three vette owners buying one.
Old Dec 15, 2004 | 11:52 AM
murnutz's Avatar
murnutz
Same thing just happened to me. I just replaced mine a few months ago and that one has bit the dust. Got a new one that I'm gonna put in this weekend. Hope this one lasts longer than a few months.
Old Dec 15, 2004 | 12:01 PM
RandW's Avatar
RandW
Make sure you use contact cleaner on electrical connector, oil and goobers will ruin your new sensor.
Old Dec 15, 2004 | 12:09 PM
fstrthnu01's Avatar
fstrthnu01
Well, now my oil pressure is set at 120psi!!! I think it might be the weather change b/c today is one of the colder days we've had down here...started the car up for lunch and the oil pressure was pegged! Is this hurting the car at all? Is it worth replacing if the new one if its just gonna go bad?
Old Dec 15, 2004 | 01:26 PM
vectorz's Avatar
vectorz
http://forums.corvetteforum.com/showthread.php?t=958008
A DIY step by step with all the pictures included.
Old Dec 15, 2004 | 01:39 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
great write-up by vectorz. i hope i never have to use it, though.
Old Dec 15, 2004 | 02:53 PM
thec5vette's Avatar
thec5vette
Same issue here....I am changing it today...
I wonder also if we just leave it like that.....would it be OK?
Old Dec 15, 2004 | 03:37 PM
vectorz's Avatar
vectorz
In all honesty, it looks like it would be a lot of trouble to do, but once you do it, you'll realize how very easy it is.
You can do it in less than an hour, following the directions in my DIY. The part is only $35 from gmpartsdirect.com also.
Old Dec 15, 2004 | 03:43 PM
devo's Avatar
devo
dOES ANYONE KNOW THE COST OF THE SENSOR?????
Old Dec 15, 2004 | 07:24 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
$57.00
Old Dec 15, 2004 | 08:15 PM
vectorz's Avatar
vectorz
It can be purchased for ~$35 from gmpartsdirect.com
Old Dec 15, 2004 | 08:21 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
LOL!!! I was just gonna post a question about this very thing, was leaving the gym about an hour ago and mine was pegged at 130psi! Figured it was the sensor but was gonna check here anyway.
Good luck guys! Gonna get mine fixed under warranty along with a list of other problems in a couple weeks.
Old Dec 15, 2004 | 08:27 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
I just had mine fixed at 21st century today cost me 1 hour labor.I supplied my own sensor. Now it works fine. The sad thing is I had them put a ls6 intake on three weeks ago. Note to self if you gonna pull the intake go ahead and replace the $40.00 part while you are there.
Old Dec 16, 2004 | 12:29 AM
LoneStarFRC
I ran mine like that for a couple months before changing it and installing a Z06 manifold. As soon as I fired it up, everything went back to normal. I used a unit I picked up from RockAuto.Com made by Standard Motor Products. I think it was a part number PS308. Don't quote me on the part number as that's just from memory. It's a quality piece made with a brass body and as I remember was a little less expensive than a Delco unit. I'm familiar with Standard's line of products and they are one of the better ones.
If your installing it yourself, be sure and use the correct size socket and use a torque wrench too. I think it uses a 22mm(?) as I recall.
BTW, be sure to check that the small vacuum hose at they rear of the manifold gets re-attached when you go to put it back on. HTH
To Oil Psi Stuck At 129!
