Variable cam timing gains
Old Dec 15, 2004 | 09:13 AM
Fast one's Avatar
Fast one
Default Variable cam timing gains
Would changing the cam timing in relation to rpms yield much of a power increase? I recall seeing a cam sprocket design in an old magazine that changed the cam timing from advanced at idle to retarded at high rpms. There were adjustable stops to set the amount of advance/ retard and springs could be changed to set the timing ramp vs rpm.
