C5R Style Heads
Old Dec 15, 2004 | 08:09 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default C5R Style Heads for the LS7
J-Rod and Louis have posted on LS1Tech that the new LS7 heads have ports similar to the C5R heads and flow in the 360 - 380 CFM range!!
Looks like there will be significant off the shelf help - soon.
Old Dec 15, 2004 | 11:15 PM
leaftye's Avatar
leaftye
Swapping to the LS2/LS7 will be necessary, and the conversion isn't exactly easy. Hmm...think these will bolt onto a 346ci LS1/6?
Old Dec 16, 2004 | 10:17 AM
J-Rod's Avatar
J-Rod
No, you'll need a bigger bore... 3.900 isn't going to cut it with a 2.20" intake valve.
To C5R Style Heads
