Help Clunk in the front
Old Dec 16, 2004 | 02:40 PM
Aaron's-coupe's Avatar
Aaron's-coupe
Default Help Clunk in the front
Help!!!!
My car just started to make a clunking/poping sound this morning. It seams to only happen when I am going real slow. Actualy when I am backing out of a parking space, when the wheel is turned sharp a clunk/pop occurs. You can feel it in the steering wheel. Is this something to worry about? Is it a wheel bearing, or a bad sway bar end-link? I know that the back endlinks did go bad and it would pop.
Thanks for all of your help
Old Dec 16, 2004 | 05:34 PM
ANTIVINUM's Avatar
ANTIVINUM
I have T1 bars and my end links pop all the time
Old Dec 17, 2004 | 09:14 AM
Aaron's-coupe
The more I think about it the more I think that it is the end-link. I mean look my car has 90,000 miles and has the plastic end-links (well the front does, I replaced the back a few months back). When I replaced the rear ones the bushings were all wore out. I just want to make sure it was not a bad wheel bearing.
Old Dec 17, 2004 | 04:36 PM
HP_Addict's Avatar
HP_Addict
I hear the end links will make a popping, especially if you do not get them real tight. They are easy to change I would start there.
Old Dec 17, 2004 | 07:39 PM
VetteSiNz's Avatar
VetteSiNz
I have the same problem in my 04 with a base suspension....it started to makes ckunking noise when I turn left going slow. I hear these clunking noise in the front passenger side. I'll check my end links tommorow...this is no good.
Old Dec 17, 2004 | 09:01 PM
leaftye's Avatar
leaftye
I didn't think the plastic endlinks could pop! Have you had any work done on the front in the past few weeks?
Old Dec 17, 2004 | 10:36 PM
Aaron's-coupe
I haven't done any changes in a while. I have to change to oil on sunday, so I will look around then.
Old Dec 17, 2004 | 11:28 PM
David Plum's Avatar
David Plum
Possible lower ball joints with that milage
To Help Clunk in the front
