Bang/clunk!!!
Old Dec 16, 2004 | 04:57 PM
Dirty Howie's Avatar
Dirty Howie
Default Bang/clunk!!!
Every once in awhile when I make a slow left turn I will hear a loud bang/clunk type noise. It sounds like it is right behind and to the drivers side of me.
I have no drivablitiy issues. I'm thinking feul tank? I do sometimes have problems filling my tank...maybe a loose float or something.
Any ideas...??????????
Old Dec 16, 2004 | 11:54 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Check the torque on your left rear Hotchkis bushings.
Assuming they use factory settings:
upper: 49 lb-ft.
lower: 70 lb-ft.
Old Dec 17, 2004 | 12:27 AM
Dirty Howie
upper: 49 lb-ft.
lower: 70 lb-ft.
Bob (hows it going?)
You know .... I wouldn't know how to check the torque on my toe nails.
Andy did the sway bar install so I will have him check it next time I see him.
Sounds closer to the to me than the rear sway bar....
Old Dec 17, 2004 | 12:42 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
GOOD Howard - I was actually considering signing up for your run this weekend (then I looked up where Newbury Park was on Mapquest). Figure I'd be too wiped from x-LA traffic by the time I got there to enjoy the run!
I know you said that, but those kind of noises are almost always sway bar... especially if you have no driveability problems. It could also be the end link (I think the Hotchkis ones are adjustable). Noise can be transmitted in weird ways through the chassis.
In any event, Andy can check all this stuff in short order.
Old Dec 17, 2004 | 01:30 AM
Dirty Howie
I am about 20 minutes closer than Andy's. You would have no traffic. Another guy is coming from anahiem. You should come!!!
Old Dec 17, 2004 | 01:43 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
PM sent.
Old Dec 17, 2004 | 07:27 AM
c5inphila's Avatar
c5inphila
People have complained about this noise most times it happens when going up a driveway. Sometimes the sheet metal between the seat and the fuel tank buckles. Try driving with your hand on that panel -pass. side. walt
To Bang/clunk!!!
