Ripples in the air coupler?
Old Dec 17, 2004 | 02:23 PM
RABVET4272002's Avatar
RABVET4272002
Default Ripples in the air coupler?
What is the reason for the ripples in the air brige coupler? -- Is it only for ease of assembly (adjustment for misalgnment), or did GM purposely incorporate it into their design to purposely create turbulence which does not seem to make any sense?-- I would think that smooth uninterupted air flow would make more HP? Maybe at 405 HP it is unimportant, but the more we modify to increase power then maybe it then becomes an issue requiring a aftermarket "smooth" style coupler???
Old Dec 17, 2004 | 02:28 PM
Dope's Avatar
Dope
Resident moron
The 'ripples' are for flexibility.
You can buy cheap aftermarket flexible rubber/silicone hoses to replace it.
Dope
Old Dec 17, 2004 | 06:14 PM
vdiblasi's Avatar
vdiblasi
Default Cheap hoses
Where do we buy these cheap hoses?
Victor
Old Dec 17, 2004 | 09:03 PM
leaftye's Avatar
leaftye
The ripples makes it easier to install & remove. On some car the ripples allow the engine to rock without breaking the connection.
Old Dec 18, 2004 | 12:47 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
After 8 years this, simple part would have changed if there was any benifit in adding HP. The new 7 liter Zo6 500 Hp engine is using this same type coupler.
The Engine design team is not sleeping.
Save your 50 dollars
Old Dec 18, 2004 | 12:00 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
I just think the smooth ones look nicer.....and you can choose colors as well.
Old Dec 18, 2004 | 12:13 PM
David426's Avatar
David426
Might pick up 1 horsepower if you are lucky
Old Dec 18, 2004 | 12:49 PM
DsC5's Avatar
DsC5
Old Dec 18, 2004 | 01:04 PM
USA-VET's Avatar
USA-VET
Old Dec 18, 2004 | 02:58 PM
Joe's Eray's Avatar
Joe's Eray
Save your money.
Old Dec 18, 2004 | 03:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
8 bucks at home depot, fernco 4x4 drain coupler.
To Ripples in the air coupler?
