o-ring specs for Tire pressure sensor?
Old Dec 19, 2004 | 05:56 PM
IFLUBYU's Avatar
IFLUBYU
Default o-ring specs for Tire pressure sensor?
I know this has been posted multiple times, but I couldnt get anything out of the search tool.
Thanks in advance.
Old Dec 19, 2004 | 10:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What specs do you need?
Bill C
Old Dec 19, 2004 | 10:36 PM
IFLUBYU's Avatar
IFLUBYU
what are the size specifications for the o-rings on the tire pressure sensors?
Old Dec 19, 2004 | 11:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have an 02 sensor sitting infront of me and it does not use an O ring. It uses a stepped rubber piece that fits into the hole in the rim. Is your TPS the new style or the old wing style? I'm not sure what type seal is on the old style.
Bill
Old Dec 20, 2004 | 12:18 AM
Shylor's Avatar
Shylor
Well his car specs show he has a 2000 coupe, so the sensors are the old style that use the o-ring.
Old Dec 20, 2004 | 08:30 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Bill
UMMmmmmmmm.............................. ....
we're talking TIRE PRESSURE SENSORS here.
did you READ the complete post?
Old Dec 20, 2004 | 08:39 AM
c54dan's Avatar
c54dan
#9 o-rings from Home Depot. Make sure you torque the retaining nuts to the correct spec.
Old Dec 20, 2004 | 08:57 AM
IFLUBYU's Avatar
IFLUBYU
bingo, thats what I was looking for,thanks!
Old Dec 20, 2004 | 01:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
helped me out this morning too!
Old Dec 20, 2004 | 01:26 PM
PaPaChoc's Avatar
PaPaChoc
OK, we know what number it is now what size is it? ID. OD Cross section?
Old Dec 20, 2004 | 05:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
02 ZO6 Pressure sensor!! 97-2000 are one animal and 2001 - 2004 are another. Yea I know 02 could of been taken as O2 oxygen sensor!
Sorry for the confusion
Bill C
Old Dec 20, 2004 | 05:45 PM
Gimmesum HP's Avatar
Gimmesum HP
I got mine from a Chevy House but they didn't come in package marked with any size. These things are a PITA so buy extras and be prepared to have leaks if you don't get them to set correctly the first time around. When I had the Mallet wheels mounted I had to change the rear passenger o-ring 3 times to get it sealed and stop a slow leak.
Old Dec 21, 2004 | 01:04 AM
jdmvette's Avatar
jdmvette
Night Owl for life
the #9 o-ring baggie is marked as: 5/8 X 7/16 X 3/32 and they fit perfectly.
Old Dec 21, 2004 | 07:44 AM
PaPaChoc's Avatar
PaPaChoc
Thanks! I have access to an “O” ring kit just in case I need to get some.
Old Dec 21, 2004 | 07:32 PM
IFLUBYU's Avatar
IFLUBYU
Can't seem to find the torque spec... Anybody?
Old Dec 21, 2004 | 08:59 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Got mine from the dealer, called washers, PT# 10268438
I sure you can find these cheeper some place else.
Old Dec 22, 2004 | 07:16 AM
Midwest Vette's Avatar
Midwest Vette
The torque per the helms manual is 106 ib in.
Hope this helps.....Ron
To o-ring specs for Tire pressure sensor?
Old Dec 22, 2004 | 08:38 AM
c54dan's Avatar
c54dan
Notice the torque is in INCH-POUNDS not FOOT-POUNDS...
Old Dec 22, 2004 | 09:50 AM
jdmvette's Avatar
jdmvette
Night Owl for life
0.33 ea at home depot...
Old Dec 22, 2004 | 12:00 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Thanks in advance.
Subject: Tire Pressure Monitoring System (TPMS) Grommet/Seal Availability
Source: Chevrolet Dealer Technical Service Bulletin
Number: 03-03-10-004 - (04/07/2003)
Models: 1999-2003 Chevrolet Corvette
2000-2003 Cadillac DeVille, DHS, DTS, Seville
Important
Do not replace the wheel mounted Tire Pressure Monitoring Module if the grommet requires replacement. Replace only the grommet.
The above vehicles may include an on-wheel tire pressure monitoring module that is an integral part of the tire valve stem. This system utilizes a replaceable grommet at the wheel air valve opening. If this grommet becomes damaged or unserviceable, order GM P/N 25715243 for a replacement. DO NOT replace the wheel mounted Tire Pressure Monitoring Module.
Part Number: 25715243
Description: Grommet, Tire Valve
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
