Replace the lumbar seat control?
Old Dec 19, 2004 | 09:46 PM
sakins.02vert's Avatar
sakins.02vert
Default Replace the lumbar seat control?
The lumbar seat control on my drivers seat in my 2002 vert is stuck on. I pulled the fuse and it now doesnt drain my battery. I am wondering, is this something pretty easy to replace? or should it be done by the dealer? I bought the car in another state (2 hour drive) and they said they will fix it but I didnt want to have to spend the whole day going to CT to have this done? If they send me the new switch do you think its doable? Anyone done this before? Thanks
Old Dec 19, 2004 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why do you think you need to go back to the state that you purchased the car in? Why cant you just take it in to a dealer that is close by?
Bill
Old Dec 20, 2004 | 09:15 AM
sakins.02vert
Because the GM warrantee expired on Nov 30, 2004. The only reason the guy in CT will fix it is because he gave me his own 60 day warrantee.
Old Dec 20, 2004 | 11:36 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
The seat is pretty easy to work on. A service manual helps avoid guessing and changing out parts unnecessarily. If the switch is actually the problem, it's no biggie to change yourself. If it's not and you end up burning time diagnosing the real issue you may or may not come out ahead.
Old Dec 20, 2004 | 12:40 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
had same problem on my '98, ended up being a corroded control, it's easy to take apart and clean with a knife(20 minutes), if you need a hand i'm located in avon,ct
Old Dec 20, 2004 | 03:48 PM
sakins.02vert
Do you have any directions you can send me that explain how to take the seat apart to get to the control? I don;t have a service manual. Sounds like I should get one...
Old Dec 23, 2004 | 02:42 PM
SteveDoten's Avatar
SteveDoten
Default seat ctrl
the contacts are in the control on the side of the seat, philips screw in front and on under the recline handle, unplug it and take it apart
Old Dec 23, 2004 | 04:02 PM
ronwc's Avatar
ronwc
I have a 98 conv and my battery has been draining slowly. I suspected the drivers power seat, removed fuses and that's what it was. I took the switch out (no big deal) and popped the switch open. On the inside was a metal plate that I assume was there to sychronize the outer handle with the three switches, probaly to allow only on switch to operate at one time. It was borken in half and I assume that it was probably leaving one of the switches on. I've removed it and everything seems good so far, we'll see. I also looked at where the switches contact and could see no burns or corrosion at all.
To Replace the lumbar seat control?
