Scratched driver side window
Old Dec 20, 2004 | 10:16 AM
LYCON's Avatar
LYCON
Default Scratched driver side window
Can anyone tell me how to stop the outside of the driver side window from getting scratched when I put up and down. I think this is a simple problem to fix but I haven't seen anyone address it yet.
Old Dec 20, 2004 | 10:32 AM
C5dream's Avatar
C5dream
I am going to tag along on this post. I have the same problem with my drives window. Would like to hear a fix for this also.
Old Dec 20, 2004 | 01:40 PM
Kid's Avatar
Kid
I third this!!
Old Dec 20, 2004 | 04:29 PM
LYCON's Avatar
LYCON
anyone anyone
Old Dec 20, 2004 | 04:43 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Mine has had a scratch for a long time.
Old Dec 20, 2004 | 09:02 PM
slicksilver11's Avatar
slicksilver11
same here, the only thing that i thought of was maybe something got caught in the door between the rubber and the glass.
Will be interested if that was not the case.
Old Dec 21, 2004 | 09:52 AM
LYCON's Avatar
LYCON
Ttt
Old Dec 21, 2004 | 10:43 AM
SilverBulletZ06's Avatar
SilverBulletZ06
Agreed
Old Dec 21, 2004 | 12:09 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
I have experienced the same problem on the driver side but have no explanation, sorry to join the club.
Old Dec 21, 2004 | 12:42 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is the sand and dirts that gets trapped between the window and the stripping, you need to run a rag between the two from time to time to stop the sand and dirt build up.
Old Dec 21, 2004 | 06:37 PM
keith5's Avatar
keith5
Active Streak: 90 Days
Of all of the problems I've shared on this forum - column lock, leaky differential, crummy stock headlights, rocking seats, bad H2O pump, etc.
I thought I finally had a unique problem on my '98 Coupe. I have a vertical scratch in the drivers window from rolling up and down.
Now, I see that I cant claim an exclusive defect... I'm kinda bummed...
Old Dec 22, 2004 | 01:21 PM
LYCON's Avatar
LYCON
Ttt
Old Dec 22, 2004 | 11:44 PM
GerryInOrange's Avatar
GerryInOrange
Default Instructions on how to adjust the window
Although the title of the thread below is different, there is some great information which may help you ...
http://forums.corvetteforum.com/showthread.php?t=947457
One of the posters replied with detailed pictures and instructions on how to adjust the window ... the best I've seen. One of the adjustments can deal with scratching the window, if the door/window mechanism is what's causing the scratching.
Gerry
Old Dec 23, 2004 | 09:44 AM
luminary's Avatar
luminary
Gerry
Thanks Gerry, I thought I had posted those at some point. You are exactly correct, one of the adjustments can eliminate (or cause, don't ask me how I know ) the scratching. The place it will scratch is about 1/3 of the way in from the back of the window. If the scratches are in a different place than that, then the window strip might have some grit in it.
Old Dec 23, 2004 | 12:01 PM
LYCON's Avatar
LYCON
My scratches are on the outside of the drivers window about 6-7 inches from the front of the door. They are deep so I don't think dirt could have done this. Once the door is fixed I will have to replace the window thats how deep these are.
To Scratched driver side window
